Thread: CYA and weight vs. oz.
    Aug 2007
    I am adding CYA to my pool and going from a level of 0ppm to a target of between 30 and 40ppm. I see where the pool calculator says in my 14000gal pool that I need about 78oz. of CYA. I have so far got 3 pounds of CYA in the dissolving stage. Can I assume that 3lb.s of CYA is = to 48 oz.? Sorry if this is such a stupid question
    24' AGP vinyl, 3/4hp Pentair 2-speed, Pentair Quad DE 60
    Pool Rover Jr.
    If you roll the cursor over the 78oz value, you will get a more 'useful' value in the box next to 'size' or 'temp', where it says "mouse over a field for detail"
    8000 gallon 20' x 48" round vinyl frame pool, 12" sand filter (don't have the specs on the pump), TF100 test kit
    Handy Links: PoolMath, TF-100 Test Kit, Pool School, CYA-Chlorine Chart
