Thread: Hayward 250
    Hayward 250
    I have a Hayward 250 Natural gas heater. About a month ago it started popping when turned on. The pops get so forcefull that the above ground pipes move with each bang. I am sort of a novice and figured maybe air was in the lines and expanding. I have tried to configure every flow change possible to see if that would help or eliminate the problem. It doesn't matter if it is configured in spa mode or pool mode.
    Any help?
    4JawChuck's Avatar
    Jun 2010
    Winnipeg, Manitoba, Canada
    223
    Re: Hayward 250
    It might be the pressure switch cycling on and off which causes the flame to cut in and out when the igniter tries to light once it "sees" pressure. You can bypass the pressure switch with a jumper wire to determine if its the cause.
    55 Kilolitre in-ground 18'X36' vinyl lined kidney shape, 1HP pump, Jacuzzi 250lb sand filter, RayPak Delta T 200K BTU natural gas heater. New PoolWerks "Blue Diffusion" liner on May 26th-2011
    Avatar is my pool!
