Thread: Hayward Aqua Vac
    Hayward Aqua Vac
    My pool builder dropped off our Aqua Vac a couple days ago while I was at work. I threw it in the pool yesterday and again today. However it seems that the cleaner doesn't hit one side of the deep end. I can see some debris that has been there for a couple days.
    1. If I run the cleaner for another cycle is it likely that it will get this spot?
    2. If I don't have the Aqua Vac Plus (comes with a remote) can I buy a remote separate and use it with my machine?
    76549 Liters -- Cartridge Filter -- In Ground -- Vinyl -- TF-100 Test Kit -- AquaVac Robotic Cleaner -- UV Sanitation -- Winter Safety Cover -- Installed 2010 -- Southwestern Ontario, Canada
    Latest Test Results June 25:
    FC - 6, CC - 0, CYA - 40, CH - 110, TA - 90, pH - 7.5
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Hayward Aqua Vac
