Thread: Custom Design ICF Pool. How to Line it/where to get it?
    30' round AGP, 22,000 gallons, Hayword 1.5hp pump, 250 lb sand filter
    22,551
    Re: Custom Design ICF Pool. How to Line it/where to get it?
    I know nothing about the foam but they can make a liner in about any shape you can imagine. Lots of good measurements are what's required to get a good fit.
    This simple answer is this: if you can measure it we can make a liner for it.
    Almost all inground liners are custom made. If the pool shape is far from normal then you can expect to pay around 20% more for the liner.
    Making Liners Since 1997
    Pool Liner Factory Outlet
    4JawChuck's Avatar
    Jun 2010
    Winnipeg, Manitoba, Canada
    223
    I have also thought they should only installs pools up north here with insulating foam as an intermediate layer between the earth and the pool, sure would reduce the heat lost to ground during these colder months.
    For a conventional pool I would use them to back the side panels, some cutting to go around the braces would be required but not hard to do with foam, the bottom can be straight foam or a liner fabric could be used over top. Not sure on their crush resistance for a bottom though, that might be a sticking point...might have to check their applicability to this usage type. I'm thinking that spray foam would be a lot easier to apply though. If your thinking about a free form gunite style pool you still need to put steel down for the cement to frame the cage, I wonder about ground heave with frost though...hence why you don't see many gunite/concrete pools up north.
    I do know that most of the heat loss is through the water surface as radiation and evaporation, you might want to look into what percentage really goes into the earth side and bottom as heat loss...I have a feelings its a fraction of the heat loss from the waters surface to atmosphere. I'm thinking that you would be better off to use a standard pool configuration with spray foam on the sides (forget the bottom) and come up with an automatic cover that is insulated, I'm getting tired of my cheapo "bubble wrap" style solar cover already and wish I had a motorized insulated cover to keep the pool clean and warm.
    I am seriously thinking about this kind of system for my pool, insulated slats baby...thats where its at!
    http://www.brookforge.co.uk/product-...ers_covrex.htm
    ...if only they didn't want an arm and a leg for the system.
    The insulated foam tops are not that expensive though, I might go that route instead.
    http://www.brookforge.co.uk/product-...rs_thermal.htm
    55 Kilolitre in-ground 18'X36' vinyl lined kidney shape, 1HP pump, Jacuzzi 250lb sand filter, RayPak Delta T 200K BTU natural gas heater. New PoolWerks "Blue Diffusion" liner on May 26th-2011
    Avatar is my pool!
    What kind of prices can I expect to pay?
