Thread: Back wash pipe leaking
    My pool is 15 months old, only used about 6 months. Noticed I was losing water, the backwash pipe has a steady stream of water running out. I have played around with the valve and it dosent stop it.
    Water comes out of the pipe even when the pump is off. Could it be some type of gasket ? Seems too soon to be having problems. Thanks
    Above ground 33 ft round 52 in. high
    Approx. 25000 gallons
    Hayward Dreamline Sand filter holds 250lbs sand
    Hayward CL-200 chlorinator
    Hayward 1.5 hp 67 GPM pump
    30,424
    Re: Back wash pipe leaking
    From your brief description, the gasket inside the multiport valve sounds like the culprit.
    It's a reasonable DIY project if you are inclined to do so.
    22,551
    I agree with Dave, the spider gasket has probably rolled out of the groove. Shut off the flow to the filter and take the top off of the valve and you should be able to tell if the spider gasket is the problem. As Dave said, it's relatively easy to replace.
