Thread: Below skimmer
    Below skimmer
    Question:
    I am in Ohio. In ground pool. Do most people just drain below the skimmer but keep the water above the other returns? I was at the pool store and they said they just blow out the lines that are below the water level and cap them. They said they don't add antifreeze to these lines (one return and one that pushes water in the pool), but do add it to the skimmer above ground. Does this sound right?
    Also, I have found that I probably have some sort of small air leak in my pipes and alway loose my prime if the pump is off for a short while. I am wondering if this will cause problems in the winter.
    16 x 38 inground pool, 20K gal, vinyl liner, 0.75 HP Hayward Superpump (SF 1.0, 115 V), Hayward Pro Serier Top Mount 24" sand filter (300lbs sand) with 62GPM design flow fate and 3.1 sq ft effective filtration area, Kreepy Krawly cleaner
    Sep 2008
    Ontario Canada
    14
    Re: Below skimmer
    We drain our pools between 6-8" below the bottom of the skimmer faceplate to allow for water displacement from the rain/wintersnow melt. We add antifreeze to return lines below water by pouring into the return lines then slighty uncrew one till we see some pink seep through then close then we do the same for the others. The air leak will not affect adding antifreeze to your skimmer line.
    I can always find something to fix on your "perfect" pool
    Dec 2009
    Central Massachusetts
    2,690
    Re: Below skimmer
    If you blow the lines the right way, you dont need antifreeze. There a lot of ways to close a pool. A lot of guys use antifreeze, others dont. A lot never do and its fine as long as you blow the lines out the right way.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
