Thread: Low pressure error on heat pump
    Rockadile's Avatar
    Sep 2008
    Schwenksville, PA
    21
    I have a 2 year old pool with an AquaComfort electric heat pump. The heater was working fine last year, but I have not used it at all this year. I tried to turn it on yesterday and I am getting a low pressure error. This year, I decided to open the pool (and maybe close it) myself. I had the pool company close it last year and I thought it was pretty straight forward. Could I have missed something that they did to winterize the heater last year that might be causing this error? Any other ideas before I call the repairman?
    Thanks!
    Equipment, etc.
    30,000g IG Quartz
    Goldline Aqua Logic SWG
    Hayward SwimClear Cartridge Filter
    AquaComfort Heat Pump
    Hayward Phantom Turbo Cleaner
    Taylor K-2006 & K-1766
    Procrastination is the key to flexibility.
    Ft Lauderdale, Florida
    1,455
    Re: Low pressure error on heat pump
    Make sure the area around your heat pump is clear of debris, heavy vegitation, walls, or air flow blockage. Also, ensure your fan is operating properly. Or call the manufacturer to address this condition, as a low refridegrant condition.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
