Thread: Waterproofing the skimmer
    Hi,
    I have a poured cement pool in which I'll be adding a skimmer this week. The section of wall where it is going is being repaired so the skimmer will be fully incased in cement in a single pour. Does the cement flowing around the mouth of the skimmer make a waterproof seal or do I need to do something else? Is there a sealant that I'll need to put around the mouth of the skimmer?
    Thank you,
    Cement 12'x30', in the neighborhood of 50 years old. Restored, 1.5"plumbing, 1hp super pump 2, Hayward swim clear cartridge filter, Summit2.5t heater,Hayward SWG t-9 cell, Nexxus Blanco lights, pentair bermuda gunite skimmer.
    Guest
    Re: Waterproofing the skimmer
    The mouth (are you using a Swimquip U-3 skimmer?) will be angled and all plastic, and you will tile into the mouth. That will create a watertight seal.
    But I'm not tiling the pool?
    Guest
    Not even at the waterline? That is going to be tough to keep clean.
