Results 1 to 7 of 7
Thread: swimming with SWG
    racerboy6996's Avatar
    Aug 2010
    Albemarle, NC
    103
    swimming with SWG
    Ok, I know that all of the pumps & SWG I have seen have warnings on them to only run them while no one is in the pool.
    Is there an actual reason for not running an Intex SWG while someone is swimming or is this just a warning to keep people from suing the company?
    Intex 16ftx32ftx52in rectangular / Hayward 2 speed pump / Hayward 21in sand filter / Intex SWG / still saying solar panels coming next year
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: swimming with SWG
    Intex stuff is usually not UL rated for swimming pools, so no bathers in the pool while it's running.
    Aug 2010
    Albemarle, NC
    103
    ok. I thought maybe the reasoning behind the pumps saying that was due to no suction entrapment devices with above ground pools
    Ft Lauderdale, Florida
    1,455
    I believe Intex is the only swg that has that warning.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Feb 2010
    Blessing, Tx (South of Houston)
    82
    swimming with SWG
    On my intex swg it says no use when in pool but it is UL listed. The reasoning I've gotten is intex products are made to work with intex products. The pumps are not UL listed so can not be used, therefor no swg also. However I use a pentair system, with the intex swg, so good to go.
    Intex 18' AGP - Intex SWG - 19 inch Sand Dollar Sand Filter - 1HP Pentair Dynamo Pump - 4X20 Solar Panel - Goldline Solar Controller.
    Aug 2010
    Albemarle, NC
    103
    swimming with SWG
    Great info everyone. Thank you
