Results 1 to 19 of 19
Thread: Why exactly is Gunite/Concrete more expensive than Vinyl?
    Aug 2010
    Nyack, NY
    35
    What is it that makes a Gunite/Shotcrete pool so much more expensive than a vinyl lined pool?
    Arent they both equally labor intensive?....Can someone who has experience with both builds chime in as to why its almost a $10,000+ difference in the quotes?.... if not more
    ~When I was a child I caught a fleeting glimpse out of the corner of my eye.....~
    -Name the song and group!-
    30,432
    Re: Why exactly is Gunite/Concrete more expensive than Vinyl?
    Not at all. A gunite pool is much more labor intensive.
    Dec 2009
    Central Massachusetts
    2,690
    More labor, more materials, basically. Multiple crews usually as well. There's the excavator, steel installers, shot crete crew, plumbing, tile guys, and finish guys. The finish is a specialized trade. Plaster, pebble tech, etc all requires skilled tradesman to do it.
    A vinyl pool is easier to build. If all goes well, they can do a vinyl start to finish on 10 days. It comes in as a kit. The hole is dug, walls go up, floor is done, plumbing is in, drop in a liner, and you have a pool.
    It also depends on where you are. In florida, you can do a gunite pool as cheap as vinyl. Up north, its about double. Lots of reasons for it. Not as many gunite builders, labor is more expensive, unions, etc.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Concrete prices have gone up too so fiberglass is fairly competitive with gunite in our area.
    Mark
    Mar 2007
    Coastalish 'down easter'
    4,160
    Quote Originally Posted by bk406
    10 days???????????? 3 or 4 is more like it (as long as you realize that the deck has to wait 6 weeks for the ground to properly settle. I can give you the breakdown on how the build would go if you'd like.
    Back to the OP, concrete is pretty expensive and it takes dozens of yards of crete to build even a small pool. There's also the rebar, gravel, plaster/ pebbletech and tile to take into account (as was previously mentioned).
    Luv& Luk
    -Ted
    Dec 2009
    2,690
    Quote Originally Posted by waste
    10 days???????????? 3 or 4 is more like it .
    10 days is more realistic. You know that And yes, I know exactly how it goes. Or were you talking to the OP?
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    I wished my pool would have gone up in 10 days or less! I'm STILL waiting (since beg. of Aug.) for the ground to settle before we pour a concrete skirt or apron around it. Being that we have had a long dry spell doesn't help.
    14,700 gal. 14 x 28 rectangle with 2R IG by Hydra Pools, 1 hp Hayward Maxflow ll, Hayward 24" Sand Filter, Aquarite Electronic SWG, one Aqua Genie Complete Skimmer, two main drains, four returns, 2 spa jets in steps, 30ml Tidewater liner. Taylor K-2006 Test Kit
    Dec 2009
    2,690
    Its generally 10 days or less from nothing to a pool. The deck takes longer. I went the entire winter before i put in my deck. I would actually wait closer to 6 moths to put in a deck on an overdug pool.
    Aug 2010
    Nyack, NY
    35
    guys....Im a little confused about the waiting 6 weeks to 6 months thing before pouring the deck???
    Are you using these estimates with just a dirt backfill in mind?
    I was under the impression that the proper backfill is using a gravel or a 3/4 pea stone...if either of these are used, I thought you could immediately pour the concrete deck without risk of any settling and cracking?
    Am I wrong about this?
    And in regards to concrete/gunite pools, is there any backfilling involved?.....if not, there's really no risk of settling decks that will crack?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Welcome Neighbor
    Proper backfill will certainly reduce the risk but the longer you wait, the better. Whatever backfil material you use, it will settle. Some much less than others, but it will happen. Both gunite and vinyl pools need to be backfilled as the hole they put in the ground is larger than your actual pool.
    Given the point you are at in the season, your best bet is to have the pool built this fall and pour the decking in the spring. There is nothing like a good set of freeze/thaw cycles to settle your backfil
    Quote Originally Posted by Rico Laguno
    Having just watched six guys bust their tails from 7AM-4PM non-stop, 6 14-yard gunite trucks come and go, and a deafening compressor truck with agitator, hopper and pump deal, I can tell you it is very labor intensive. It only took one day, yes, but it was really six "man-days", the machinery and trucks involved were probably over a million dollars sunk cost, and you need some talented concrete shapers. Not cheap.
    24k gallon inground with 500 gallon spa, 580sqft Jandy cartridge filter, Jandy ePump 2HP variable speed pump, Jandy 1400 SWG AquaCal Heat Pump, Diamondbrite Aqua Quartz plaster
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Link to his pool build new-gunite-pool-in-westchester-ny-t27029.html
    GSX...given you are a stone's throw from Nyack, perhaps you can PM Rico you're builder's name/reference Assuming you're happy with the job thus far...looks like it's coming along great from the pics.
    Apr 2010
    Buckeye, AZ 85326
    619
    Quote Originally Posted by dmanb2b
    Welcome Neighbor
    I'm a bit confused about this statement: With our pool the hole was dug ten to twelve inches over spec, then the shotcrete crew shot it in to conform to the shape of the hole that was excavated. There was zero backfill needed?
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Quote Originally Posted by Shane1
    Welcome Neighbor
    If you had a level property and the conditions were right for zero backfill, that's great And I will agree there is certainly less backfilling needed when building a shotcrete pool, but where backfill is needed, I'd rather see it settle before putting the deck in.
    Johnl's Avatar
    May 2008
    Montgomery County, PA
    88
    When I had my pool built 5 years ago, I had the opposite experience. We had quotes from two vinyl pool companies and one plaster pool company. One of vinyl quotes was almost 10k over the plaster and the other vinyl quote was the same price as the plaster, but with less equipment/options.
    23K Gunite IG Pool
    Waterway Crystal Water SVL56 Pump/1.5HP AO Smith Motor
    Hayward Star-Clear Plus Cartridge Filter C17502
    Aquarite 40k SWG
    Polaris 360
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    My dilemma is the building permit runs out in January 2011. I already spent $250 on permits and I don't want to spend more for an extension.
    All that is left to do to get a final inspection is to put a wire mesh around the pool. Before we can do that, the ground needs to settle a little more. Hopefully we will get some much needed rain this weekend.
    Dec 2009
    2,690
    Check on the permit. Thats actually not a big deal, at least around here. The only time a permit expires and you have to get a new one is when no work was ever started. You are in the process, so it should be fine. Call the building inspector and find out for sure, but I'm pretty sure you would be ok on the original; we were. In fact, we took 2 years to actually close it out and get a final, but we were working on things on and off the whole time.
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    On the actual building permit that is taped to my front window, it has January 11, 2011. It's only good for 6 months. The pool builder said I could ask for an extension.
    I may call the city just to see what they say.
    A city realistate official came by on Tuesday to see if the pool was in the ground with water and the pump working. Around here, they give you 3 months to do that or they can condemn the project. They consider it a hazard. She saw the water and pump working. Took a picture and told me to enjoy.
    Dec 2009
    2,690
    Call the inspector, they will give you an extension.
