Results 1 to 13 of 13
Thread: Liquidator Stopped Liquadating
    Nov 2007
    Austin, TX
    69
    This has me a bit baffled. I have had my Liquidator running very successfully for several seasons. Just over the past few week, I noted that it was no longer keeping up with the chlorine demand. First thought it was all the debris from recent rains. Now I notice that the chlorine bed is not going down. The water flow, as measure by the flow meter is correct. Both of the float valves are working properly. Water is clearly flowing through the tank. But no chlorine is being drawn from the bed. The bed usually drops gradually and I top it off every four or five days. It has been about 10 days and no drop.
    Any ideas or similar experience? I'll probably break it down and clean everything and start it up again. But I do not see any "white stuff" around the valves and have not had problems with build up in the past. I'm sure a clean and restart will get it back to normal, but I am really curious what could stop the diffusion of chlorine out of the chlorine bed.
    My Pool
    15k Gal Gunite Pool w/8 ft Spa w/Spillover
    Hayward DE Filter + DE Separation Tank
    Legend Sweep, Pentair Gas Heater
    Stenner Metering Pump for Liquid Chlorine Injection (15 gallon tank)
    22,553
    Re: Liquidator Stopped Liquadating
    As long as water is flowing in and out of the LQ the higher concentration bed has to diffuse into the lower concentration liquid.
    Did you make any modifications to the unit? (such as the upgrade)
    Have you changed brands of chlorine lately?
    Have you added scented or other speciality chlorine lately?
    Nov 2007
    Austin, TX
    69
    No changes of late to the Liquidator. I did replace my filter about a month ago, but I have gone through a few jugs of bleach since that unscheduled repair. None of the plumbing changed and the flow was the same with the new filter.
    Using the same Chlorox unscented from Costco.
    My Pool
    Guest
    I think the chlorine from Costco is either 4 or 5%. How many gallons do you toss in? What has the air and pool temperature been in your area? Also, make sure your flow meter ball is not stuck. Disconnect the hose going to the pump basket (out) and make sure you have flow while you are running.
    22,553
    Sal may be onto something. I'd definitely bump the flow meter to make sure the ball isn't stuck or even adjust the flow valve a bit to make sure it'll change with the flow.
    Even using weak bleach, you'd still see the bed level go down over time it just might not keep the same FC level as before.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by salp
    I think the chlorine from Costco is either 4 or 5%. How many gallons do you toss in? What has the air and pool temperature been in your area? Also, make sure your flow meter ball is not stuck. Discount the hose going to the pump basket (out) and make sure you have flow while you are running.
    Mine hangs occasionally. A little tap frees it up.
    Guest
    I took mine out completely! Since I have to check with my test kit to really know what is going on in my pool, I saw no need for the flow meter. It's a nice visual, but that's about it. I'd rather test and know than rely on a little floating ball!
    SW Indiana
    9,199
    Quote Originally Posted by simicrintz
    I have to run my valve on a different setting for long-term solar on/solar off times, so I need to be able to see where I'm setting. My flow seems really touchy, with 4 being perfect for my pool, but slightly above 4 emptying the tank in a day.
    Guest
    My solar cycles on and off by itself, so it can really be challenging sometimes on the flow, as you say. I just pick a happy medium and check the chlorine level often (I did it once 5 times in one day, and my wife thought that was a little excessive. Sheesh ).
    You must be running on the upgrade, huh?
    SW Indiana
    9,199
    No, running straight factory fittings and hoses. 18psi without solar, 21psi with solar full on.
    Guest
    Wow, and you can empty the tank in a day How long do you run your pump for?
    SW Indiana
    9,199
    Depends on the season. Usually as long as there is sun on the panels, which is about 9.5 hours at the max.
    Mar 2007
    Virginia Beach
    272
    If you have check valves in your system, try removing them. One might be defective.
    6000 gal inground fiberglass
    1.5hp pump / sand filter
    Liquidator
