Thread: Best cover for 18x33 aboveground with full deck?
    I am closing my pool for the first time and want to buy a good/easy to install cover. It measures 18'x33' inside dimensions....also has a full flush deck all the way around with railings. It previously had a cheap rectangle tarp/cover with many different length ropes tying it to the railings and water weight bags all around the edge with a ball underneath. What is a decent cover? Thanks. Dave
    South Central NJ
    3,192
    Re: Best cover for 18x33 aboveground with full deck?
    How wide is the deck?
    What is it made of?
    Scott
    Owner of - PoolGuyNJ LLC
    I guess the deck wraps around one end of the pool (about 6 feet before it steps up about a foot and then goes another 10 feet.....on the one side it is about 8 feet to the edge....only 3/4 the length or so. The entire pool has a 2 foot flush aluminum deck around the whole perimiter. Dave
    South Central NJ
    3,192
    A tarp cover with water bags is what I suspect is best here. The decking won't hold anchors for a safety cover. The torque of the spring on the anchor would likely pull the anchor out, especially with a snow load.
    Scott
    Mar 2007
    Coastalish 'down easter'
    4,160
    Turbo, welcome to TFP!!
    They make safety cover anchors that 'clip' onto the outside edge of AG aluminum decks. Unfortunately, I have no idea who makes them nor how to get them However, these little clips have standard brass, screw up anchors and seem to have worked well on the 3 pools I've seen them on.
    Just a thought
    Luv& Luk
    -Ted
