Results 1 to 14 of 14
Thread: Are these the correct caps to use on my return jets?
    flyboy320's Avatar
    Jul 2009
    Burlington, Ontario, Canada
    216
    These caps seem to be very loose in the threads when I screw them into the return jets. The pool builder used them last year when he closed and I was going to use them this year when I close myself, but they do seem to be very loose. I have to use a lot of Teflon tape to get them to at least give some resistance when screwing them in.
    Are there any other types out there that work better, maybe rubber plugs?
    10K gal IG, vinyl, 1 HP Jandy Stealth pump, Jandy CS cartridge filter, Delta UV system, Hasa Liquidator
    22,551
    Re: Are these the correct caps to use on my return jets?
    If they're that loose I'd just buy new plugs. I like the rubber expandable ones but those screw in's work good to.
    WestSidePool's Avatar
    Cincinnati, OH
    424
    Those look like a standard PVC cleanout plug.
    I actually used these on my pool last year, might switch to the rubber ones this year.
    But if you said they are loose I probably wouldn't trust them.
    These are the ones that have a rubber gasket on them to help keep a water tight seal.
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    X-PertPool's Avatar
    Exeter, PA
    1,385
    use SP-1022 C style plugs, instead of that plug for better results
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    flyboy320's Avatar
    Jul 2009
    216
    Thanks guys, I like the idea of the rubber gasket...
    Might have to look for these up here in Canada. Any idea who sells them in the US (maybe I can get them shipped up).
    flyboy320's Avatar
    Jul 2009
    216
    Well I managed to find the SP-1022 C style plugs! Tried them out today and they fit MUCH better than the previous ones I had, so thanks for the great advice!!
    X-PertPool's Avatar
    Exeter, PA
    1,385
    keep in mind that sp-1022 c style plugs rely on the return faceplate to make a seal. Sometimes the plates can crack around the screw holes, when this happens we change the plates to avoid any chance of leaking after installing the plug.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    flyboy320's Avatar
    Jul 2009
    216
    Thanks for the tip Kevin...
    I'll have a look at them and make sure they're OK. If any do need swapped out, is it just a matter of removing the four screws on the face plate and then they just come off (ie., no unscrewing of the faceplate itself)?
    X-PertPool's Avatar
    Exeter, PA
    1,385
    yeah just the four screws, sometimes there is some algae behind the plate that you can rub off too.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    DaveNJ's Avatar
    Toms River, NJ
    520
    Just replaced four covers on my pool. Aftering reading X-PertPool's response in this thread. The old ones had more cracks on the backside, very brittle and pretty much fell apart.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    Having trouble removing the fitting for the directional return to put in the plug. It has 2 grooves but cannot find anything in my workshop to fit them. Any ideas?
    _________________________________________________
    Above Ground Pool - 27' round
    Hayward Pump
    Cartridge Filter
    Michigan
    Quote Originally Posted by uidb5259
    believe it or not i ended up using a standard stiff putty knife.
    AG 24' round 15k gal
    cartridge filter 125sf
    X-PertPool's Avatar
    Exeter, PA
    1,385
    If your talking about the threaded fitting that can sometimes get stuck in the wall there is a tool that fits into the notches on the inside of the fitting for better leverage. Also a 1.5 " wood chisel will fit the grooves just be careful as the chisels are very sharp
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    bobgio's Avatar
    Sep 2013
    Niagara Falls, Ontario, Canada
    14
    Quote Originally Posted by X-PertPool View Post
    I have seen several posts that you recommend the sp1022 c style plugs. However, every where I check says that they are for concrete pools not vinyl.
    I am very curious as to why this is such a confusing topic. Why are the proper plugs not sold everywhere. I too cannot decided which to use....HELP!
    These are the ones I have seen as well by Feherguard made in Canada (1.5 inch):
    Bob G, 18x36, 21000 Litre, inground, starite system 3 cartridge filter, raypac heater
