Thread: Pool Pictures with decking issues
    Nov 2009
    South Florida
    6
    http://s865.photobucket.com/albums/ab213/johnnysouth1/ Hello everyone 1 year new to pool ownership still learning need help with pool decking some pavers are loose and no grout or sealer recently purchased this way thanks Johnnysouth
    pool size 16,000
    Jandy cartridge filter
    IG with spa and waterfall
    Diamond brite blue
    Jandy 1.5 hp 125gpm
    hayward navigator cleaner
    Dec 2009
    Central Massachusetts
    2,690
    Re: Pool Pictures with decking issues
    Can you describe the issue a bit better? Are they out of level? Heaved? or just a little loose?
    Pavers are not grouted or cemented in. They are laid close to one another and "lock" together. A sand with a polymer then is poured onto the surface and swept into the joints. Water is then put onto the deck and the polymeric sand hardens a bit.
    You may need to re-sand your deck. Any paver deck, walk, etc needs to be re-sanded here and there every few years.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Nov 2009
    South Florida
    6
    Quote Originally Posted by bk406
    Hello The real issue with the pavers is some are heaving to one side ,not always level ,weeds and grass grows between the pavers so I am constantlying using roundup to kill the weeds it works well. I see quite a gap from the coping to the actual next pavers just seems to be untidy I actually removed a few and laid more sand mixed with a little thin set and that worked well also I am wondering should I sweep in polymeric and finish with a sealer??
    pool size 16,000
    Diamond brite blue
    Jandy 1.5 hp 125gpm
    Guest
    Polymeric sand should automatically seal when lite water is applied. No need to seal.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,054
    Sounds like your pavers are settling. You may just have to use a compacting machine to tamper the pavers. I would call your pool builder and have him come out to inspect them. He might take care of it.
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Dec 2009
    2,690
    A compacting machine wont work, really. What you need to do is to remove the pavers that are out of level, re-screed the sand or stone dust under them, and re-set them. A compacting machine will not fix the underlying problem. It's actaully not too difficult. No need to seal them either, just as Sal said. Once they are level, use polymeric sand.
    Brent, it may not be his pool builder that put them in. Most pool builders dont install the pavers. Your was the exception, not the rule. Most use a landscaper that specializes in hardscape to build a pool deck. But you correct in that a call to the installer might help. If the pavers have been in for several years, they will likely charge him for the fix as settling a bit is usuallly not guaranteed for more than a couple years.
