Results 1 to 12 of 12
Thread: I thought I had a problem with algae..but not sure..help
    Jun 2010
    Waco, Texas
    66
    Ok, I started back to college and got caught up in my studies so I let the pool slide a few days.
    So when I checked it was
    TC 0
    PH 7.8
    CH 30
    CYA 40
    TA 130 (always high)
    My water was cloudy and had a green tinge to it. I assumed it was algae. I added my MA to lower PH and then prepared to shock pool I added enough bleach to reach 16 according to pool calq but it went to 20 (taken at dusk).
    This AM before sun fully out my chems were
    FC - 20
    CC - 0
    TC - 20
    PH 7.5
    TA 130
    CH 30
    CYA 40
    So, I didn't lose any chlorine overnite and my water still looks murky...not the pretty clear it was before. Taking the water out of pool and putting it in a clear glass...it looks clear...but in the pool it looks pale greenish and not all clear. So, I am not exactly clear as to the cause. Any ideas?
    Kawfy
    AGP 16x32x52 Cornelius, guesstimate of 15400 gal. Dished out in center to 5 ft , Counter sunk 1ft 10"
    Jacuzzi 1.5 hp pump, 300 lb sand filter
    Full hot sun in Heart of Texas
    30,432
    Re: I thought I had a problem with algae..but not sure..help
    Give it another day or so. Green is almost inevitably algae or metal content and it is a real stretch to think that metal has suddenly precipitated in your pool.....a REAL stretch!
    Chalk up the lack of FC loss as just one of those things and monitor you FC daily and keep your filter running 24/7. I think you will lose more chlorine than can be accounted for by the sun and that your water will clear.
    Jun 2010
    Waco, Texas
    66
    should I continue keeping the shock level up if it falls later? I am going to add more MA to get my Ph to 7.0. Also, should I consider adding Borax at this time? Or should I wait?
    Thanks in advance
    Kawfy
    30,432
    Yes, If your FC drops by more than around 2-3ppm daily, keep it up for a few days. When the water looks crystal clear, do an overnight FC loss test (see Pool school) and if you pass that test again, let it come on down to normal.
    I see no reason to lower your pH to 7.0 or even adjust it.... certainly not while your FC is above 10ppm.
    Borax is an optional additive that will not help you clear your pool. I personally don't use it but you might consider using it after your pool is stabilized.
    Jan 2010
    Central Valley, CA
    233
    Have you brushed the bottom to see if the green is on the liner and expose any algae to FC?
    Garden Leisure Voyager 12x24 AGP, 7500 Gallons, Hayward Power Flo Matrix 1 HP pump, dual speed, Hayward XStream Cartridge Filter, 120 GPM,
    Jun 2010
    Waco, Texas
    66
    Quote Originally Posted by Sportsman
    Yes, I have brushed and vacuumed I plan to do it again later today. I have noticed quite a bit of "dirt" that has settled on the floor of the pool since last evening. Is this dead algae? <---- if this is a stupid question...consider the source
    Kawfy
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    More than likely it is dead algae. Dead algae is often confused with dirt as you discribe it. If you continue to do what you are doing it should clear it up (vacuuming, filtering 24/7, brushing).
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    Jun 2010
    Waco, Texas
    66
    Looks like I am making progress. Pool no longer has a green tinge but is still a bit "cloudy" although I can see the floor pretty well now. I will keep it up until I am satisfied with the clarity.
    Quick question, Why would I not adjust my PH? I thought Pool School said that a lower PH helps keep the chlorine more effective on the algae...Did I read that wrong? Also, my PH ALWAYS drifts high. I started out with a TA of around 350 with my fill water. Took a while and I am at about 130 still working on it. Rain always drives it back up.
    Kawfy
    22,553
    Don't just keep it up till you're satisfied with the clarity. Keep it up till you pass the OCLT (overnight chlorine loss test).
    You shouldn't adjust your pH while your FC is above 10ppm because high FC affects the pH test and it'll read higher than it actually is. Until your FC gets below 10 you really don't know how much it's affecting your pH reading so you should just wait till it comes down to adjust the pH.
    Jun 2010
    Waco, Texas
    66
    Bama...ok, thanks for the info. Looks like the overnight test, this morning was a winner -no loss. I am going to give it one more good scrubbing/vacuum and do one more overnight test, just to be sure. It shouldn't hurt anything right?
    Kawfy
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Sounds like a plan
    22,553
    That's how I would do it.
    I always like to see the OCLT passed two nights in a row before I declare the battle won.
