Thread: will cya hurt the lawn?
    Jan 2010
    Claremont california
    100
    Hello friends,
    I am about to dump some of my water to lower my 80 ppm cya level. I was wondering if I could use the water from my pool to irrigate my Saint Agustin lawn. I live in S. Cal and we are currently experiencing a drought. My FC level is at 2 ppm. PH is at 7.6
    Please advice,
    George
    22k plaster pool kidney shape. Pentair 4000 de series 48 ft. 2 SKIMMERS, 2 drains (pool and spa), 3 returns (2 pool and 1 spa) gas heater and pentair intelliflow , Underwater pentair light.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: will cya hurt the lawn?
    Mine seems none the worse for several soakings. And get this - my CYA is now down to 90.
    I hope you let the chlorine run low intentionally just for this pumpout/lawn watering, because that's waaaaaay too low to maintain with CYA, well, anywhere.
    Mar 2007
    San Rafael, CA USA
    12,082
    Soil bacteria (those that survive the chlorine onslaught, so migrate in later) will love the CYA "food" you give to them and will break it down to ammonia giving your lawn an extra nitrogen (fertilizer) boost though the quantity is rather low.
    Jan 2010
    100
    Quote Originally Posted by Richard320
    Yes! that is correct. my intention was to lower the FC so that the water there will be less FC for the lawn.
    George
    Jan 2010
    100
    Quote Originally Posted by chem geek
    Thanks for the tip! I will start dumping asap.
