Thread: Solar Pill
    Alamo, CA
    7
    Solar Pill
    Come on, reducing evaporation lost and therefore temperature loss by producing a film in the water!!!??
    Anyone with any experience with this product, "Solar Pill"?
    (1) Pool size - I think about 35,000 gals? Pool is 20' x 40'
    (2) Sand filter
    (3) AG
    (4) Vinyl
    (5) Pump: 1.5 hp Hayward super pump Filter: Hayward S240 (I think 65 cfm)
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Solar Pill
    aka Snake oil Garbage. Solar cover is what you want.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Solar Pill
    It isn't as good as a real cover, but it there isn't a lot of wind then it can work to reduce evaporation and therefore heat loss. The problem is that a breeze or wind will push the one-molecule thick layer towards one end of the pool exposing a lot of water. So I wouldn't call this snake oil in that it isn't completely bogus, but it's not nearly as effective as a real cover and needs calm conditions. One of the original products, HeatSavr, uses cetyl alcohol as its primary ingredient (along with dispersant such as isopropyl alcohol along with some calcium hydroxide). There's a long thread about this on another forum here.
    Alamo, CA
    7
    Re: Solar Pill
    Thanks for the info and link, Chem Geek.
    (2) Sand filter
    (3) AG
    (4) Vinyl
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Solar Pill
    Quote Originally Posted by chem geek
    For the solar pill, given there is no mention of calm conditions required and it's questionable benefit, i'd still call it snake oil. Snake oil is still oil, just doesn't work as well as the marketing around it would make you believe. At least Heastsvr calls out the calm condition requirement.
