Thread: Hayward Super II Seal HELP
    Aug 2010
    Queen Creek, AZ
    14
    I need to replace the seals in my pump I am looking for some does and don'ts. More so on DONTS I don't want to damage the pump and have to fork out more money.
    Any help would be greatly appreciated. Going to try and get it done this wknd.
    12,000 Peanut Pool
    Sand Filter
    Zodiac SWG
    In-ground Pebble tech
    Not sure on pump size
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Hayward Super II Seal HELP
    Probably the biggest mistake you could make would be to install the seals backwards, just follow the instructions. Also note how things are put together as you take them apart. And a little pool lube on the o-rings can make things go together a little easier.
    Mark
    South Central NJ
    3,192
    SuperPro makes a Go-Kit that has the seals, seal plat gasket, volute gasket and lid gasket. Highly recommended.
    Scott
    Owner of - PoolGuyNJ LLC
    Mar 2009
    Huntsville, AL
    156
    DO: Trip the breaker before you start.
    The following are links to a two-part Youtube video for replacing the shaft seal in a Super Pump - it is not your exact pump, but it might give you an idea what to expect (like take the cover off the back of the motor to access the flats on the motor shaft so you can get the impeller off). I recently changed my motor and seals and it really wasn't hard, but it did help me to see someone else do it first.
    http://www.youtube.com/profile?user=...27/e1RWd6lae9Q
    http://www.youtube.com/profile?user=...26/WT6FaK3MX4o
    Hope that helps.
    Gordon
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
    Aug 2010
    Queen Creek, AZ
    14
    Thanks for the help. Got it done and no leaks!!!! It is much quieter now too.
    Oh BTW it was 108 today.
    12,000 Peanut Pool
    Sand Filter
    Zodiac SWG
