Results 1 to 12 of 12
Thread: 1st time pool closing
    Hello all,
    I have read the "Pool Closing" topic at the beginning of this forum, I am waiting for the water temp to get below 60 degrees before I start it is currently at 70 degrees.
    My 1st question (of many I am sure ) is, what chemicals do I need to close my pool ?
    Thanks
    Fatcat07, In ground pool, Vinyl Liner, 18 X 36 Pool size, 30,000 Gallons
    Hayward Heat Pump - Hayward HeatPro Heat Pump
    Hayward Filter DE2420 - 24 sq ft (I think)
    Hayward pump - Not sure of the model number
    Suffolk, long Island
    Re: 1st time pool closing
    Also: Do you need to put any Antifreeze in the pool itself? or just the lines?
    16x32 inground pool 3ft-8ft (18,000 gallons) Vinyl lining New DE Filter
    22,551
    The only thing you really need is chlorine. You can use Polyquat 60 but it's optional and not usually recommended if you close after it's cold enough and open before it gets warm.
    Tater -- You only add antifreeze to the plumbing. It would take an enormous amount to protect the pool and then how would you get rid of it??
    Thanks for the reply
    So I just want to map out my steps to make sure I close my pool the correct way, please review and add or correct or re-arrange anything you think will help:
    • Wait until water temp gets to 60 degrees or below
    • Bring my chlorine up to shock level
    • Clean the pool of leaves and any debris
    • Bring water level down to about 6 inches below the skimmers
    • Disconnect and dismantle the pump and filter
    • Blow out the return lines (I have three) and insert stoppers
    • Remove skimmers baskets and insert the gizmos in the skimmers
    • Remove diving board and ladders
    • Cover the pool with the loop loc cover
    • Done ???
    Two questions:
    1) Is there anything I can add/do to the pool to prevent the swamp that I had to deal with when I opened it at the beginning of this summer ?
    2) I was told by the pool people that I had a very high phosphate level (<1000) which I have been keeping at bay by keeping an eagle eye on my chlorine levels. Is this something I should take care of now ?
    Thanks to all .......
    Ottawa, ON, Canada
    153
    Did you forget how it works? Once you close the pool after 2 weeks of cold weather, you get a few weeks of super nice swimming weather and say "I wish I had closed it later".
    19.5k gallons in ground, P4 panel with turbocell SWG, 1hp Hayward superpump II, sand filter, Heater low nox 250k btu heater, solar cover on rocky roller
    thecanuck22's Avatar
    Jun 2010
    Vernon BC
    58
    Quote Originally Posted by fatcat07
    • Done ???
    Two questions:
    I would change steps 2 and 3, remove debris and leaves before you shock.
    I am not sure you need to actually disconnect and dismantle your equipment, I just pull drain plugs on pump housing and filter and done.
    Phosphates....thankfully we havent been pitched that stuff yet for our inventory I would hate to have to start selling it!!!
    I wouldnt personally worry about it.
    Blessed is the man who can laugh at himself for he will never cease to be amused.
    To teach is to learn twice.
    My Pool. 20 x 40 120,000 litres (about 30k gal) sand filter, a pump of some type...lol & a bunch of neighbourhood kids.
    Thanks .... I will swap 2 and 3, clean 1st and then bring the pool up to shock level. I dismantle the equipment (filter and pump) because I store it in my shed for the winter.
    Ok so the only chemical I need to add to the pool is chlorine (bleach) ? Do I have to add anti-freeze ? also is there any other chemical I can add to the pool that will help me when I open the pool next spring ?
    Thanks
    Dec 2009
    Central Massachusetts
    2,690
    Why do you dismantle your pump and filter? Thats not necessery.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Jun 2010
    Vernon BC
    58
    Thanks
    rv antifreeze to the return lines and skimmer lines and any line that might still have water in it, plug off your return jets and skimmer opening. I use to always add a bottle of algaecide and some sort of stain and scale inhibitor, i still might this year, i am undecided, it certainly doesnt hurt.
    Hello all,
    I am starting to get ready to close the pool finally and since I have let it go a little bit (laziness) , the water has gotten a little hazy. So I am in the process of cleaning the pool, I know I have been asking about what chemicals I need to close the pool properly and have gotten some responses but I am still unsure of what is needed.
    I took a trip to the pool store to buy some DE and saw a pool closing kit that contained the following items:
    5 lbs. Chlor Brite
    5 lbs. Fresh' N Clear
    1 qt. Algae Control
    1 ltr. Metal Free
    1 qt. Ultra Bright
    10 ct. Test Strips
    Free Water Bottle
    1 ltr. Pool Magic + PHOSFree
    Complete Pool Opening & Closing Instructions
    Are these chemicals needed to close the pool ? Is it a wise buy ?
    If not could someone please list what is needed.
    Also once I lower the water below the returns and blow them out and place the stoppers on them do I have to raise the water back over the returns ?
    I also need to know if once I disconnect the filter and pump (winter storage) and the gizmo and return stoppers are in place I am planning to add the anti-freeze from that location, do I fill the return and skimmer lines with anti-freeze ?
    Sorry for all the questions but I am a 1st time pool owner and this is my 1st closing .... I need to make sure I do it correctly.
    Thanks in advance for all the help and advise ...
    DaveNJ's Avatar
    Toms River, NJ
    520
    With the water balanced the only thing I add is bleach. I don't remove the equipment, just cover it. It takes about 2 gals of anti-freeze to do the spa returns/drains pump basket and pool returns and skimmers.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    22,551
    You don't need any of that stuff.
    Chlorine is all you need. I'm assuming you have a cover so you'd need to raise your FC to shock level, blow out and plug all the openings add about a gallon of antifreeze to each pipe. Filling the piping with antifreeze is optional. As long as you're sure you've blown the water out a little antifreeze in the bottom of the pipes is all that's required.
