Thread: Should I be concerned
    Aug 2010
    Oklahoma
    21
    I have a pool shell (just the shotcrete) and we had some rain recently. Water was leaking in around one of the light niches. Should I be concerned or will the plaster take care of this? I'm a worrier so just something that has been keeping me up at night. Thanks.
    25k Gunite, Easytouch, Intelliflo VS3050, TR-60 with ClearPro Technology, 2 Magic Stream Laminars, IC40 SWCG
    Guest
    Re: Should I be concerned
    No worries. Can you see a physical hole in the shotcrete, or is it just weeping in through the material? If it is a hole, just mention it to the PB and it is an easy "fix".
    Either way, it is nothing to worry about. The plaster will stop it.
    Aug 2010
    Oklahoma
    21
    It is weeping through between the shot and the niche. Thanks for the reassurance. I need it!
    Guest
    They should have "dished out" around the niche for the plasterers to fill in and waterproof. They also should have left a pretty good sized hole in the deep end of the pool for the ground water, if any, to come up. The plaster company fills that also, so they are used to this kind of stuff.
    Better safe than sorry, so good question though
