Thread: Check a Leak Detector
    May 2009
    Trenton NJ
    497
    Has anyone one tried this product? Does it work?
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Re: Check a Leak Detector
    You can achieve the same results with a 5 gallon bucket. You may need to repeat the test if it rains, though.
    http://www.troublefreepool.com/pool-...leak_detection
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    X-PertPool's Avatar
    Exeter, PA
    1,385
    I use a regular bucket too, although a possible advantage to this device would be that bucket tests are more accurate if the water in the bucket stays the same as the pool (by putting the bucket on the steps) so if you don't have steps this would be another way of getting an accurate "bucket test"
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
