Results 1 to 15 of 15
Thread: Algae every 2 wks despite maintaining FC of 7+ in SWG pool
    New Orleans, LA
    20
    It came back today. Here are my readings
    FC - 8.0
    CYA - 60 (though I usually keep it closer to 75)
    TA - 70
    Salt - 3100
    pH - 7.5
    I don't understand why it keeps coming back. I run the pump on high 12 hours a day. The FC stays high. I haven't been running the SWG much because the FC has stayed double digits since the last shock.
    It is unusual the CYA dropped below 70 (probably because I added water to the pool 2 days ago with the FC at 11) and it has been very sunny since, but should that matter when the FC stays so high?
    15'x30'x54" oval AG; 12,500 gallons; Aquatrol SWG; Cartridge filter; 2-speed, 2-HP pump; 2 return jets
    Re: Algae every 2 wks despite maintaining FC of 7+ in SWG pool
    I have been having the same issue. Mustard Algae coming back after lots of scrubbing and shocking. I just got done with a four day Mustard Algae shock, no signs of any. I'm waiting to see what if anything grows. Like you, I was keeping my FC levels around 10 with a CYA of 60ish, and seemingly having no affect on the algae growth.
    17,000 Gallon plaster pool. Hayward Perflex EC65 DE Filter. 3/4 HP Hayward Superpump converted to dual speed. CircuPool RJ45. Skimmer, floor drain, two returns.
    Guest
    Have you shocked your pool at 18ppm and did an overnight chlorine test for loss? Have you cleaned your cartridge filter? what is your pool water temp?
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by jparr
    Mustard algea is tough to get rid of but enough chlorine will do the trick. At 60 ppm CYA, shock level for mustard is around 35 ppm. If it is mustard, you dont have near enough chlorine at 10 ppm to even touch it.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    New Orleans, LA
    20
    Quote Originally Posted by salp
    I shock it to at least 22-24 ppm, sometimes higher. I leave the SWG going to maintain FC levels while it's clearing. I clean the filter every 2-3 weeks (not since last algae about 2 weeks ago, though). Pool Temp has been around 85.
    Guest
    bk406, hit it right on, if it is mustard algae, with what data you gave us, you need to shock around 35 - 38 ppm.
    Mar 2007
    San Rafael, CA USA
    12,082
    Yellow/mustard algae is about twice as slow to kill as green algae so shock levels need to be higher. It also likes shade so can hang out behind light niches and under removable ladders. You need to put in poles and other equipment that would get back into the pool at some point after shocking. Also, keep the high shock level for at least an extra day beyond no visible algae, <= 1 ppm FC overnight drop and <= 0.5 ppm CC. If any of the algae survives, it can grow again unless the FC is kept at around 15% of the CYA level which can become impractical/expensive which is why it's better to completely kill it if possible.
    New Orleans, LA
    20
    Are you answering me or jParr? Are you saying mine is likely mustard algae, too? The regular 24 ppm shock does seem to take care of it for the time anyway. Mine's not under shade or removable ladder necessarily. However, it does appear to begin in areas where the water doesn't circulate as well i.e. furthest from the return jets.
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    dsharp, what does your algae look like? I do not see a CC or TC test result in your post. Have you done the overnight FC test? If not I recommend you do so and post those numbers so we can help you out. Without those numbers it is hard for us to determine if you have algae. It may look gone but the test may prove otherwise.
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    22,551
    How are you testing?
    One thing bothered me in your initial post.
    When and what was your last shock?
    And, what's "not much" run time for the SWCG?
    New Orleans, LA
    20
    I shocked about 2 weeks ago (last algae sighting) Since then the FC stayed so high I had the SWG off or, for the last couple of days, at 25% during the 12-hour pump run I give it each day. Normally, I run it around 40% to maintain. CC was 0 - 0.5. Overnight I lost 0-0.5 FC so I'm sure the algae was gone. If it comes back, I'll make better note of whether it was more yellow-ish. I hadn't considered that.
    My theory - One thing that may contribute is the two 50-lb sand bags in the pool that weigh down the steps are enclosed in giant "baggies" and there always appear to be algae INSIDE the baggies. I figured it was staying sealed in there, but it could be some gets out and feeds into the pool. Possible?
    Apr 2010
    Fleming Island, FL
    431
    Repeating Dave's question, how are you testing?
    Carlos
    22,551
    You need to open those sand bags and get some chlorine in there. If algae got in algae can get out.
    If it were me I'd get rid of those bags and use 5 gallon buckets instead. Fill them with sand and water then add a pint of bleach to each and close them up tight.
    New Orleans, LA
    20
    Quote Originally Posted by benavidescj
    I have the TFP test kit and test for FC and pH every day; CYA about once a week. TA every two weeks or so as that doesn't seem to fluctuate much. The SWG has an automatic readout for Salt level.
    Oct 2007
    Valrico, FL
    542
    Some types of organics love to hide. For example on my pool, they were hiding in the air piping of my spa jets!. Until I ran shock level water back through the air piping I was in the same boat.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
