Thread: First cleaning of Pentair 420 cartridge filter
    ajones02's Avatar
    Feb 2010
    Keller, Texas
    118
    No questions here necessarily but I did want to share my experience of my initial cleaning of my pentair 420 cartridge filter over the weekend. just a bit of background. shortly after the pool was completed, the PB needed to come out and repair the scuppers that flowed into the pool. that required sawing the coping on both therefore getting considerable dust from the concrete into the pool which of course led to the PB's maintenance guy having to come over and vacuum the pool twice. at that time i asked the PB to have the maintenance guy clean the filter. he said that it would be fine since it was a large filter. so at that time, i noted the pressure on the filter and jotted it down. this was back in late february/early march. since then, we have had 3 pool parties with considerale bathers but that was it. typically it's just the wife and i. nothing that i would consider a large bather load by any means. also, a chocolate lab that loves to swim whenever we let her. the problem there is with the dog hair that enters the pool. GROSS.
    so i had notice that the water over the past couple of weeks hadn't looked as "polished" as it had previously. my chemicals that i test for using the TF100 are all in line and always have been. i went through the process of shutting everything off and removed the top of the filter tank. i was SHOCKED at how the cartridge filters looked. all 4 of them had dog hair, dirt, sand, muck (for the lack of a better word) and grass clippings stuck to mainly just one side of them. i could actually scrape this mixture off with my hands. in a word, DISGUSTING. so after getting them hosed off and then soaking them for an hour in diswashing detergent (cascade) and then hosing them off again, they were all back to as white and clean as i could get them. i reinstalled everything and got everything to working again with no leaks and turned the pump back on. the couple of things that i noticed immediately was the pressure dropped about 5 psi and the water flow into the pool and over the spa overflow was considerably better than before. i was actually amazed at that. . i'm sure that since this was the first time and it had been 6 months since the filter had been installed, that was part of the issue or at least hope so.
    so from the FWIW department. i read numerous post on here that some cartridge filtered pool owners didn't notice any increase at all in filter pressure before cleaning their cartidges. everyone with larger cartridge filters might want to take notice of that. so moving forward, i will schedule two cleaning of the filters during swim season just to be on the safe side and chalk this up to a great lesson learned.
    BTW, the water looks better today than it did before the cleaning.
    17,800 gallons, Pentair Clean and Clear 420 Cartridge Filter, Inground, Blue Granite Pebblesheen Interior, Pentair Intelliflo VS-3050 Pool and Spa pump, Pentair Whisperflo 2HP Water Feature pump, Pentair .75 HP Booster Pump for Pentair Legend pool cleaner, Pentair EasyTouch 8-function remote, Pentair IntelliChlor SWG.
    22,553
    Re: First cleaning of Pentair 420 cartridge filter
    Great write up. I'm sure it'll help someone else that may be having issues and just don't know it.
    ajones02's Avatar
    Feb 2010
    Keller, Texas
    118
    thanks bama. i know there are many other factors that impact the timing of cleaning the cartridge filters. in my case, part of my issue is the relation of where the pool sits, the prevailing wind and the mulching of my grass during the cutting season. this does and will continue to contribute to my regular cleaning particularly during the summer months.....
    my next purchase will be skimmer socks. i have read here also that anything from knee high's to paint strainers can be used for that.
    is there a site that members of this forum use to order skimmer socks or are the other methods just as effective?
    22,553
    Most of us buy Knee highs at Walmart the cheapest ones are the best to use.
