Results 1 to 12 of 12
Thread: Need a new cover
    Need a new cover
    Last year due to the heavy snow and ice it trashed my pool cover, need a new one this year. The local pool store offers a deal for a 25x15 oval cover (with free chemicals and air pillow) for $129.00 It has the grommets every 16" and the cable and tensioner etc... Chemicals included are two gallons of winterizer, two floating containers with tabs to release over the winter months and pump conditioner etc...
    My question is.. I can go to the local hardware store and buy a 30x20 heavy duty tarp for $39.99... It may not look as pretty around the edges but I can buy the cable and tensioner for $10 plus maybe $20-30 for the chemicals.
    Anyone ever use a regular tarp and have any luck, pros/cons etc..
    Thanks
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Need a new cover
    Sure could. You can also check ebay for just the cover. The tarp or a cheap cover from ebay will likely not last for more than 1 season, but the same will be the case with your local pool store deal. We have a Namco by us and offers the same type of deal, but the chems are not needed and the cover, even the deluxe model is cheap and can be had online for 1/2 the cost without them chems.
    That said, I decided to try out an ArmorKote cover...suposedly has a 5year full replacement warranty for $108 shipped. The closing kit with cove at namco would have cost me $89...since I have no need for the chems, I figured I'd sring the extra few bucks and see if I can get more than a season or two out of the cover.
    Mar 2010
    Southern Indiana
    15
    Quote Originally Posted by dmanb2b
    Please tell me where you found the ArmorKote cover for that price? I googled because I need to buy a winter cover and the one I found was much higher. I thought it was just the size but I believe we are looking at the same size. I think I want a solid cover the mesh just sounds like it would let in too much mess. Thanks for any help or suggestions.
    24' AG pool 14,435 gallons
    Waterway 1.5 HP pump
    19" Ecokleer sand filter
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Right here
    I should be getting mine in the next day or two, so if you want to wait I can confirm if it's the real deal. Should be manufactured by HCI in Medina NY and be tan on top, blue on bottom....we'll see
    Aug 2010
    Mentor, Ohio
    24
    I am on probably my last year of the pool store cover. What a mistake. By spending $70-$80 dollars and getting two years out of them, I would be better off buying the cheap cover on ebay (average with shipping going for $40 or from poolgeek ($38 before discount) and then treat as yearly disposable throwaways with no cleaning required. If someone finds a more sturdy cover (ArmorKote?) that will truly last through the harsh winters of N.E. Ohio, I would consider it. But the proof nows needs to be in the pudding for sure. It would be cool if the Medina NY location for the ArmorKote manufacturing location had a factory store - I could have family drive there and make a discount purchase. Oh well, wishful thinking I guess.
    24' Above Ground; Hayward PerFlex D.E. Filter; Hayward 1HP Pump.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Well I just received it....IMHO, I think the Tan will will cordinate nice with my brown deck and tan pool walls, but I seriously doubt it will last more than 2 years. Unfortunately time will tell. I have noticed that the edges are double stitched and instead of grommets there are stiched in nylon fabric loops, but the actual tarp material is very thin and the tan top is not fabric, rather the same tarp material, but must just be a plastic coating. We'll see if the what the marketing states...holds up in Northeast winter conditions I know folks further north think there winters are worse, and is in fact true from a temp perspective, but IMO I think it's the constant freeze/thaw cycling that really does a number on covers/pool equipment around here.
    Anyway...it is what it is...the warranty is full 5yr on material defects/workmanship, but only 50% on material degradation (IMO...that's all that counts)....after 5 years it's further prorated, eventually down to 5% reimbursement (hah, what a joke). I'll try to take some pics in the next few days, but figured I would give you all a heads up.
    Unless this cover holds up 3+ years, I will definately just go with the cheap $40 cover every year.
    Aug 2010
    Mentor, Ohio
    24
    I will hold my breath for the next 3+ years and hope for the best for you
    I called the factory up in Medina and they gave me their distributor's website named http://www.bestbuypoolsupply.com and for the AK24R4 model number (for a 24' above ground round), the pricing is $118.99 + $16.00 for shipping as your "buy anytime price" becomes $136.
    I would need this to pretty much last at least 4 years to offset the cheap poolgeak cover (4 years x $40 = $160!). There would be no maintenance or cleaning with the cheap cover as it would go right in the trash! I am so lazzzzzyyyyyy....
    Keep us updated as inquiring minds will want to know - at least here for sure. Thanks much!
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Don't use the floaters during the winter! They will get stuck in one spot after the cover goes on with a little rain. The chlorine will fall out the bottom and since the water isn't moving you'll have a bleach spot on the bottom of the pool.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Quote Originally Posted by OhAllWet
    Thanks for the support Yes, that's the same model I received for $108 shipped, in the link i provided in my previous post. Bestbuypoolsupply is actually just one of their reseller/distributors. I found out HPI actually owns Yard Guard (in Canada) who physically produces the cover here. Anyway, just figured I would give you more info...but we'll see how long it lasts ...time will tell, but I like your "lazy" idea...that's what I told myself I would do, but like everything else I do, research etc, just lead me to buying on of the better covers I could find. Oh well you win some and lose some.
    tejensen's Avatar
    Jul 2011
    Middletown, NJ
    19
    I know this is an old post, but just curious how the cover made out during the first year of use? I ordered one yesterday and now I'm starting to second guess the decision!
    Thanks
    Tommy
    Above Ground (24' Round) 15,000 Gallons
    Hayward DE Filter (EC-40) with 1HP Pump - Advertised flow rate = 40 GPM
    Pools receives full sun for majority of the day
    TF-100 Test Kit
    Was using Trichlor with an inline chlorinator, but switched to BBB last year and water has been perfect ever since! (after draining 75% of the water to get rid of the bonus CYA that the Trichlor provided!) Thanks TFP!!!!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    No problem...the cover held up great and we had a ton of snow/ice on it last winter...even the pillow popped but the cover has no holes in it. I actually just closed the pool today and installed the cover ...it looks pretty good, plus the tan matches my pool wall color
    The biggest pain was powerwashing the grime off of it in the spring, but I'd likely get another when this one goes...hope this helps
    tejensen's Avatar
    Jul 2011
    Middletown, NJ
    19
    Cool... I feel better about my purchase now!
    Thanks again
    Tommy
    TF-100 Test Kit
