Results 1 to 14 of 14
Thread: I lose CYA all the time
    Dec 2009
    Central Massachusetts
    2,690
    Split off of this topic. This discussion diverged from the original topic, so was moved here. JasonLion
    As i've posted before, i lose CYA all the time. Not as fast as chulaman, but its considerable. i've lost, as far as I can tell, close to 30 ppm this season. I've NEVER had my chlorine go even close to zero, nor have I ever measured any ammonia, nor have i had any combined chlorines that would indicate its presence. There is something, somewhere, somehow that causes the CYA to breakdown besides the conventional wisdom here. I've stopped worrying about it and just bought and added more. (although I would like to know where it goes).
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: CYA rapidly goes to 0ppm
    Quote Originally Posted by bk406
    If the chlorine oxidation of CYA were somehow accelerated in your case, then you wouldn't notice any ammonia nor CC since on a daily basis it's quite slow and continual. What we don't know is why this known process seems to be so much faster in your own pool. 10 ppm CYA loss per month resulting in 25 ppm FC extra chlorine demand would be 0.8 ppm FC per day compared to a more "normal" 0.2 to perhaps 0.4 ppm FC per day extra due to this oxidation (most FC loss is from sunlight so this loss is lower than that so not usually noticeable).
    Dec 2009
    2,690
    I dont watch the chlorine loss that close. As long as it stays in the range it needs to be in, i dont fret over it. i have no idea what my daily chlorine loss is exactly, but ballpark it's around 2.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,731
    Bk...it's definitely not water loss, right? I know it's obvious and your savy with pools, but even the best forget about an autofill device. Anyways...just checking
    Dec 2009
    2,690
    No autofill. I lose very little water. It varies with the weather, but on average i'd say I lose 1 inch every 10 days. Its not water loss. My salt concentration goes up with water loss, so I know it's all evaporation.
    Re: I lose CYA all the time
    Why not to consider the possibility of the presence of bacteria or algae into the filter? The sand area is more than one thousand the area of the pool. Why not to treat the sand of the filter with concentrated bleach (12% or 6% NaClO)?
    Dec 2009
    2,690
    How would this cause the loss of CYA?
    Mar 2007
    San Rafael, CA USA
    12,082
    If there were areas of channeling in the filter such that there was low enough water flow for bacteria to form biofilms and not get exposed to a lot of chlorine, then eventually that could cause increased chlorine demand as much of the chlorine would spend its time oxidizing outer layers of the biofilm that would continue to be regenerated. I suppose that the bacterial conversion of CYA into ammonia could occur as well, though that is speculative in this kind of scenario and we haven't seen that before.
    Anyway, it doesn't hurt to check the sand filter, stir up its contents carefully, just to see if perhaps there is channeling or visible biofilm. I'm guessing you won't find anything.
    30,408
    Like bk406, I seem to lose a enough CYA over the course of a swim season that splashout alone does not account for all of it. Also like bk406, I simply ignore it and accept that some is going to need replacement.
    This summer, I will try to be more diligent about testing for CYA to see if I can be more specific.
    Oct 2007
    Valrico, FL
    542
    I am of the opinion that there exists a biological process to degrade CYA without producing ammonia. I believe that there is a water borne mold that can and will consume CYA. In addition it appears to be resistant to chlorine. Just my opinion.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    May 2009
    Dallas, TX
    782
    Count me in as well. I started this past summer with CYA at 60, give or take, and it dropped down to 20 by the end of the season with negligible water replacement. Even taking testing error into consideration, that's a significant loss.
    The ironic part is that the previous season I had to work so hard to bring my CYA down, that I was accustomed to thinking of it as almost immovable.
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    Mar 2007
    San Rafael, CA USA
    12,082
    When there is chlorine in the water, I'm more inclined to think that there are catalysts to the chlorine oxidation of CYA so that it just gets sped up. A drop in CYA of 10 ppm per month would consume 30 ppm FC per month of chlorine which is only 1 ppm FC per day so could well be hidden in the daily FC usage, especially if it's typically 2.5-3 ppm FC per day. One would not measure any ammonia or monochloramine in this situation since this oxidation occurs continuously at a low rate. Also don't forget that summer rain overflow can dilute the water so account for at least some of the drop.
    South Central NJ
    3,192
    During the course of another thread on another board I frequent came a discussion involving a poster's CYA level where someone quoted the following link as evidence of CYA loss that is quite contrary to how I, and thousands of others, have seen it behave in a pool. I am not Chemist but neither am I a completely ignorant oaf but this is beyond me and my understanding.
    http://umbbd.msi.umn.edu/cya/cya_map.html
    It seems to me that this is more than the "life cycle" of CYA in a pool.
    Scott
    Owner of - PoolGuyNJ LLC
    Mar 2007
    San Rafael, CA USA
    12,082
    I have referred to that specific pathway before in the thread Degradation of Cyanuric Acid (CYA), but this pathway is invoked by bacteria that have specific enzymes described in that pathway to accelerate such degradation. It does not normally occur without such bacteria just as our bodies (and most organic compounds) do not decompose (get oxidized) in air spontaneously even though it is thermodynamically favorable. In that same thread I also discuss the chlorine oxidation of CYA which is much more likely because in a properly sanitized pool there will be no living bacteria to degrade CYA. We have seen such bacterial degradation of CYA in pools that had the chlorine get to zero and I describe my own personal experience with this phenomenom in this thread and we've seen this in other pools upon spring opening when such pools are "let go" over the winter.
    Now that doesn't mean that there can't be some sort of catalyst that accelerates CYA degradation through either path though more likely the chlorine oxidation path, but we haven't identified what it is, if there is one.
