Thread: Intex Pool Pump Low Flow
    Sep 2010
    Los Angeles, C.A.
    2
    I have a intex pump with a 4ft by 15ft pool and the intex saltwater system. My saltwater system is saying there is low flow. i clean out and did the maintenantenance on the salt water system and i put a brand new filter in the water pump. But i think the pump is broken there seems to b a little but of a low flow of water in coming out. I don't know if it has anything to do with me running the pump without a filter for a week. Also now when i open the air release valve on the top of my intex pump water comes out and before air would come out not water. did my pump broke?
    Thank U
    dmanb2b's Avatar
    Apr 2009
    NY
    3,731
    Re: Intex Pool Pump Low Flow
    Welcome to TFP. It is likley a clogged impeller if you ran the pump without a filter. Not sure if that is servicable on the intex units, but if your lines are clear and the is no water movement, it likely your pump and the attached SWG is giving you the appropriate error code for low flow.
