Thread: I made a big booboo closing
    buddywiser's Avatar
    Morgantown, WV
    98
    Closed yesterday and shut everything down. I figured I'd turn off the electricity to the pump, etc, later. BUT I forgot to take the timer things off of the pump switch. So I just found out that the pump was on for about 5 hours with no water. The motor didn't fell hot at all. I guess I won't find out until next spring, but is it probably ruined?
    24000 Gal, 18x36 Vinyl
    Hayward Super Pump
    Jacuzzi Tri Clops Cartridge Filter
    Heat Siphon Heat Pump
    Dec 2009
    Central Massachusetts
    2,690
    Re: I made a big booboo closing
    Hard to say. If something is wrong, it's most likely the impeller rather than the motor. No way to know until next spring.
    Whenver a pool is closed and shut down, the pump should really be shut down at the breaker before the lines are even blown out.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
