Results 1 to 11 of 11
Thread: Mustard Algae and treatment options
    Aug 2007
    San Diego
    11
    I seem to be confused... When looking for a treatment for yellow algae i see Yellow Treat and Yellow Out. Any advice on the pros and cons on both products?
    I know Yellow Treat will consume a lot of chlorine duting treatment.
    Thanks for your insights!!
    cbisquit
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    I don't know much about either product, but I know regular chlorine brought up to shock level will take care of algae.
    Brian
    20K IG Gunite w/ raised 7ft spillover spa. 1.5 HP Hayward Northstar pump 425 sq ft Hayward cartridge filter, Colorlogic lights AquaRite SWG AquaLogic PS-8 control
    1hp pump for sheer descent
    Yellow Out and Yellow Treat are only appropriate when your CYA level is very very very high, at which point it is often simpler to lower the CYA level then it is to use those products.
    The best treatment for yellow algae is to raise your chlorine level up to high shock levels and hold it there for a while. How high you need to take the FC level depends on your CYA level.
    Aug 2007
    San Diego
    11
    JL, you're awesome!!! I guess I can stop spending my $$ on Yellow Treat and up the chlorine levels along with scrubbing, right? Assuming my CYA levels are reasonable.
    cbisquit
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    what are your numbers right now?
    Brian
    Aug 2007
    San Diego
    11
    Haven't tested this morning, currently not batteling the yellow stuff but I have in the past.
    cbisquit
    gonefishin's Avatar
    Joliet, Il.
    413
    What you need to remember is that your maintenance chlorine levels from day to day and your shock levels need to be based off of your CYA.
    dan
    33' Aqua-Leader AGP
    Hayward cartridge filter and IntelliFlo VS pump.
    Solar Heat coming ; used to own Aqua-Cal HeatWave 100k (HeatPump)
    Aqua-Rite t-15 SWG
    Aug 2007
    San Diego
    11
    So if my CYA is above 100 that's when I shock? I thought that's when water should be added to reduce CYA.
    Oh boy is this ever confusing!
    cbisquit
    Arizona
    924
    No, that's not what he is saying.
    He means the level you use to shock should be based on your CYA. If your CYA is high, you need to shock at a higher level to be effective.
    You only need to shock when your CC's get over .5 ppm
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    When CYA gets to 100 or higher you should replace water to bring CYA down again. Hopefully you will never need to do that.
    What gonefishin was saying is that your ideal day to day chlorine level depends on your CYA level, as does the chlorine level you need to use if you should need to shock the pool. The more CYA you have the less effective the chlorine is, so you need to add more chlorine to compensate when CYA is high.
    30,421
    cbisquit,
    No, you shock (elevate your chlorine level) when you have visible signs of algae in your pool or suspect they might be in there. (and some other circumstances, as well, but that's not the point of my reply)
    This stuff will all be second nature to you soon.....just keep reading and asking questions.
    You are correct about adding refill water to your pool to reduce CYA but, if you're attentive, your CYA will never get that high and you'll never have to do that.
