Thread: Leak in pump filter cover.
    Ok, I opened the pump filter cover to get the leaves out after vacuuming and now the cover is leaking.
    The o-ring fell off when I opened it, but I replaced it. I tried taking it off and putting it on again and it still is dripping when the pump is off. New to this pool stuff--What's the trick?
    It's a doughboy with a clear upright cover.
    17' x 35' oval in-ground, vinyl liner 8' deep end approx 22K of water in pool, Pool Pilot DIG-220 SWG installed March 2007, Triton TR60 sand filter, Water Ace RSP10 pump 220v/1 Hp installed Mar. 2010
    30,431
    Re: Leak in pump filter cover.
    Welcome to the forum. Try seating the O-ring again. Look for debris under the ring and look for a good fit.
    If that fails, you can lube it with silicone lube.
    If that fails, it likely needs replacing.
