Thread: Slightly confused...how do I blow out the lines?
    Apr 2010
    Syracuse, NY
    103
    I have 2 skimmers and 2 returns. The skimmer lines join at a valve on the inlet side of the pump, and the return is from the filter divides somewhere underground for the 2 returns. After I drain to below the returns, how do I use my shop vac to blow out the lines? Thanks.
    20,000 gal., Jacuzzi 250L Laser Sand Filter, inground w/vinyl liner, 1hp pump motor, TF-100 Test Kit.
    22,553
    Re: Slightly confused...how do I blow out the lines?
    Block off one skimmer and one return with a gizmo or plug and blow from the other one, then swap the plugs and blow the other ones.
    Apr 2010
    Syracuse, NY
    103
    OK thanks. Should I leave the multiport valve on "filter?"
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by edweather
    Put it to Reciruclate. You dont want to blow air through the sand. Which is what it would do set to filter. Remove the drain plug at the bottom of the filter to let all the water out of the filter.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
