Thread: AquaRite Pro Sense and Dispense w/ORP problems
    Sep 2010
    Orange County, CA
    52
    I've been reading lots about ORP in posts...enough that I probably want to go outside and shut the thing off.
    My system was turned on in February. Once the pool started to heat up, I had lots of problems. The Hayward person's been out to my house a few times since then. He's pretty helpful and gave me his card and told me to call him if I have more problems (which I have).
    For starters, he said it's pretty difficult to figure out how to use the system from reading the manual. He then took me on a tour of how it works in a few minutes that was much more helpful than the manual. After that, the system would run all day and I'd still have practically 0 FC in my pool.
    That's when I found TFP. I figured out I had a chlorine demand problem (2 pool stores couldn't figure that out). I shocked the pool with proper levels and the chlorine generator started working properly! I thought life was good. It was too good. The chlorine generator kept going. I was up to 12.5 FC.
    I finally started charting things. I figured out that ORP seems to be the inverse of chlorine: when chlorine goes up, ORP goes down and vice-versa. The Hayward person said I needed to have enough CYA for ORP to work properly...like the 60-80 range. Interestingly, I read posts about ORP here that says CYA needs to be low for ORP. My current CYA is 80.
    The Hayward person finally decided to replace the ORP probe to see if that fixes anything. Strangely, since the ORP probe has been replaced my FC has dropped to <1. The generator runs, but I'm not getting much chlorine. Before when I let it run for a few days I wound up with really high levels of chlorine. All they did was change the ORP probe, so I can't imagine how that would affect chlorine generation (it's ON). I don't think I have a chlorine demand problem this time, since CC is .2. That's been pretty constant for a while.
    With this inverse relationship between ORP and FC, should I just give up with the ORP sensor? Some of you have encouraged people to play more to get ORP to work. At this point I'm just frustrated and not happy I spent the money for this (I'm happy with the pH part, though).
    Any idea why the SWG runs and I'm not getting higher chlorine levels? This is a new system.
    salt = 3000ppm (average according to AquaRite). Temp 79F, pH 7.5, FC .6, CC .2
    TA's been pretty constant at 70-80, CH @ 280-300; SI (from the Taylor test kit wheel) has ranged from -0.30 to +0.05, so that all looks good.
    Southern CA 30K gal Pebble Pentair WhisperFlo 1HP 2 speed Hayward DE6020 filter Paramount Debris Canister Goldline/Hayward AquaRite Pro SWG (T-CELL 15) Sense & Dispense (acid) Pentair IntelliBrite 5G and GloBrite Inter-Fab G-Force slide Jandy deck jets Lion head spout Dolphin Premier Cleaner Taylor K-2006 test kit
    Jul 2009
    London and France
    574
    Re: AquaRite Pro Sense and Dispense w/ORP problems
    This post may help explain what is going on.
    http://www.troublefreepool.com/swg-o...se-t23209.html
    The new generation of chlorine sensors seem to be a better way to go that won't necessarily help you but is for information.
    Chemtrol and Prominent use the chlorine sensors in place of ORP.
    Sep 2010
    Orange County, CA
    52
    Thanks, teapot. That might explain what's going on. I see the bubbles coming out of the returns. At first I thought I was going to complain to the company that remodeled about an air leak in the line somewhere, but then I realized it only did it when the SWG is on. I know some SWGs have a clear housing so you can see it bubble and know it's working (Hayward does not).
    I'm still trying to figure out why chlorine isn't going up anymore, although maybe that's a post for a different forum.
    Jul 2009
    London and France
    574
    It's Jason you should thank Red, I just pointed you in the direction.
