Results 1 to 12 of 12
Thread: sand filter size
    Aug 2010
    Leipsic, Ohio
    24
    sand filter size
    I have a s166t sand filter (100 lb.) for my 24' ag pool. Everyone says I need bigger filter. Would a s200 (200 lb.) sand filter be big enough or should I keep looking for a bigger one, say 24" filter (300lb.)
    12,000 gal. 24' x48"AGP, hayward power-flo lx 1Hp. pump Hayward S244T 24" sand filter system.
    use BBB method and love it!
    22,551
    Re: sand filter size
    250# or 300# is what you should be looking at for that sized pool. A 16" is too small.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Yup...what Bama said. I run a 22" hayward S220T (250lb) and backwash maybe 3 times a season....and that is not even because the PSI rose significantly rather I figure after a good storm and the pool topped off, might as well backwash
    That said...if you are OK with frequent backwashing, you are on top of your chemistry and you do not have an algae outbreak...you're 100lb filter will do OK, but once you do have an issue that will require increased filtration capacity...you'll find the 100lb filter to be too small for a 13.5k gallon pool
    Aug 2010
    Leipsic, Ohio
    24
    I see both of the people that previously answered have different size pumps. I would like to only run pump 4-5 hours a day. If I get 24" sand filter should I keep my 1Hp. pump or down size pump and run a little longer? what will save more energy. I am on limited budget now and need to save where I can. Please help me out.
    22,551
    Your best bet is a 2-speed pump and a 3/4 or 1 hp is plenty. However, since you have a good pump I wouldn't change it until it goes out.
    The reason that I have a 1½hp pump (it's really a 1hp full rated) is that it was part of the package and you can't break the package!
    When I replace mine I'll be going with a full rated 3/4hp 2-speed or a 1hp uprated 2-speed.
    Aug 2010
    Leipsic, Ohio
    24
    Have one silly thought, could I just add more zeobrite to my 100lb sand filter.(only put 50lbs zeobrite in per manufacturers specs.)would it work better or just cause problems. As I said just a silly thought.
    Aug 2010
    Leipsic, Ohio
    24
    new pump
    Any one have info on this pump? would it be a good deal and would it work on hayward 300lb sand filter?
    http://www.amazon.com/gp/product/images ... 8&s=garden
    http://www.amazon.com/Advantage-Above-G ... 738&sr=1-4
    Jul 2009
    London and France
    574
    Re: new pump
    Well it looks like a pool pump, if you could get the technical details (flow rates at what head etc) that would be more useful.
    Edit: with unknown makes of pump, try to buy spares before you purchase just to see if it's possible.
    Jul 2009
    London and France
    574
    Over filling will result in expensive filter media being backwashed away, the space is there for a reason to allow the filter bed to expand whilst backwashing.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: new pump
    If your going to invest in a new filter, stick with a quality pump...not saying that the pumps above may not be a good short term deal, but eventually it will need fixin'. Hayward, Pentair and Jandy are what your looking for.
    For your pool (I have the same pool) a 0.5hp Full rated or 3/4 uprated pump is all you need...unless you want to go with a 2speed, which then I would suggest a 3/4 or 1hp pump. And you'll do just fine with a 250lb sand filter...although 300lbs can't hurt.
    Is your pump and filter fairly close to the pool?
    Also...please try to keep related topics in one thread as it helps us make sure we understand what your full set of goals are.
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    For what it is worth, IMHO look at a cartridge filter, less work, fewer problems, cleaner water.
    Mike
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    Jul 2009
    London and France
    574
    Quote Originally Posted by mcoonan
    For what it is worth, IMHO look at a cartridge filter, less work never, fewer problems, cleaner water.
    Mike
