Results 1 to 7 of 7
Thread: How much do I run my pump now?
    Apr 2010
    Syracuse, NY
    103
    Now that we've stopped swimming for the season, should I continue to run the pump, and when is a good time to close the pool? Thanks.
    20,000 gal., Jacuzzi 250L Laser Sand Filter, inground w/vinyl liner, 1hp pump motor, TF-100 Test Kit.
    Mar 2010
    Quakertown, PA
    50
    Re: How much do I run my pump now?
    Eastern PA, ready to close next weekend. I don't change the run hours for the pump until closing. Temperature (too cold to swim, we're wooses) and tree leaves usually dictate closing date. When the leaves seem to get excessive and have a calm day on weekend, that's a good day to close. High winds raise havoc when trying to install a 30 ft round cover.
    Arvil, 30ft round, 21k gal, AG/vinyl(2003), StaRiteIII hp cartridge 150ft, Polaris65.
    6/30, Temp83F (28.3C), pH 7.8, FC 2.8 ppm, CC 0 ppm, TA 100, CH 80, CYA 40, -B4O7 30, CSI-0.17.
    offgrid's Avatar
    Aug 2010
    Ottawa, Canada
    87
    We are running our pump for about 10 hrs per day. (during non-peak hydro rates)
    Up here in Ottawa, Canada we will close our pool Thanksgiving (Canadian) 2nd week of October. With the Solar blankets on over night and a few hours of heating (gas heater) we are able to keep the temperature close to 80. If we could find an affordable way to heat it we would keep it open into November. Maybe Geothermal ?
    20,000 gallon, Sand Filter, In-ground, vinyl, 1 HP Hayward Super II Pump, Natural Gas Heater, Aquarite Salt Chlorine Generator
    http://www.MY-POOL.blogspot.com
    Quote Originally Posted by offgrid
    Forgive me if this is a canadian thing and I just don't get it, but what does cost of water have to do with when you run your pump?
    25k gal vinyl AquaRite T-15
    22,542
    IT's not just a canadian thing. A lot of the world calls electrical service "hydro" due to the hydro-electric generation method.
    Don't get me on my soap box about how we're under utilitizing "hydro" as a power generating source.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Oh. Ok.
    So what do they call it if they have a wind farm or plain ol' fossil fuel plants providing their generation? Nevermind...don't need to get into here. I just didn't understand the comment because of it. That is all.
    Just plain confusing if you ask me, but I know... nobody did.
    Jun 2007
    New Jersey
    653
    From Wikipedia:
    In 1974 the Power Corporation Act reorganized the system as a crown corporation called Ontario Hydro, the name it was most usually known by. In many Canadian provinces, including Ontario, hydroelectric power is so common that "hydro" has become synonymous with electric power regardless of the actual source of the electricity.
    It's a Canadian thing.....
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
