Thread: Changing Return Outlet Size after construction
    Is it possible to change return outlet size after construction? Or is that a non-reversible decision which must be made prior to completion of plumbing?
    Pentair WhisperFlo WFDS-4 - Pentair Tagelus TA 100D
    16x32 Vinyl Rectangle 3.5 to 8 ft deep - One skimmer, One dedicated suction, three returns - 2" PVC
    Poolvergnuegen Two Wheel Suction Cleaner - One Poolskim
    Inter-Fab T7 Diving Board w/Edgewater Assy - Four Pentair Deck Jets - Intermatic T10604R
    Circupool RJ45 - Taylor K-2006 Test Kit (purchased prior to learning of the TF-100, unfortunately)
    22,547
    Re: Changing Return Outlet Size after construction
    If you're asking if you can change the return eyeball size, absolutely!
    Now, if you want to change the actual plumbing fitting size (i.e. from a 1½" to a 2") that's a different story.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Thanks. If the pool is spec'd to 2", should I specifically call out a 2" fitting size be used?
    22,547
    While that's not a bad idea, it's probably not absolutely necessary.
