Results 1 to 10 of 10
Thread: Making Plumbing Adapters For Intex SWG for inground pool
    Apr 2010
    Las Vegas
    173
    Thought I'd start my SWG install now that the temp isn't 100-110 outside and I'm to the bottom of my chlorine bucket.
    here are a few picks to start off with, I'll add more as I go. Making the 1 1/2" PVC to Intex thread on Adapters is the first hurdle. The included hose and pieces are just too temporary by design, the hose is flimsy, rubber squeeze on bushing stuff, It's all fine for temp use but I don't want this SWG to be the week link in the system. The sizes are not NPT standard and was not meant to connect to regular pipe. The rest of the equipment is great, the housing, platform cell, cable is heavy. That part doesn't look like a toy so I think it can last. Because of the size of photos (7MP each) and that I'm familiar with Photo Bucket, I'm using that.
    SlideShow: http://s762.photobucket.com/albums/xx26 ... eacc7a.pbw
    Manual pics: http://s762.photobucket.com/albums/xx26 ... ool%20pix/
    20,000 gal. 32' x 17' freeform custom pool, 3ft. shallow - 8ft. deep end, Pentair Whisper flow 2.2 HP WF-6, Purex/Triton Nautilus FNS48 DE filter, 2 Intex Chlorine Generators (retired) SR Smith Rouge Rapids curved slide, The Pool Cleaner 4-wheel model w/Hayward large leaf canister. Tightwatt pool timer Spa: Beachport 5 person/350gal. Wishlist: move Neiko Tools pump to slide, solar system, Fountain, Automation. http://www.poolcalculator.com/
    Re: Making Plumbing Adapters For Intex SWG for inground pool
    That's interesting. I think that may be the first mod I have seen where the Intex hose connector was used to connect pvc to the SWG. Thanks for sharing. How well does the barbed pvc fit into the Intex hose cuff? Is it a good tight fit or does the epoxy fill a gap?
    18'x48" Intex metal frame pool, 1600 Intex sand filer/pump combo, Intex SWCG.
    Apr 2010
    Las Vegas
    173
    Epoxy had to fill the gap, If I had liquid epoxy/hardener and some micro (Microspheres) and some fiberglass mat I could make this thing really strong.
    4JawChuck's Avatar
    Jun 2010
    Winnipeg, Manitoba, Canada
    223
    Not sure epoxy was the best choice to fill the gap, it tends to crack overtime without a flex agent in the mix and it doesn't handle UV or chlorine exposure too well. A custom machined bushing would likely been the best alternative but not everyone has the resources to do fabricate.
    Hope it works out for you.
    55 Kilolitre in-ground 18'X36' vinyl lined kidney shape, 1HP pump, Jacuzzi 250lb sand filter, RayPak Delta T 200K BTU natural gas heater. New PoolWerks "Blue Diffusion" liner on May 26th-2011
    Avatar is my pool!
    Apr 2010
    Las Vegas
    173
    Quote Originally Posted by 4JawChuck
    Epoxy was the only thing I could find that could bond the two plastics, silicone caulk wouldn't hold pressure and couldn't think of anything else. Would that marine epoxy puddy your knead together do better?
    4JawChuck's Avatar
    Jun 2010
    223
    Quote Originally Posted by civicturbo
    3M makes a structural adhesive for plastics that fills well and has high strength combined with flexibility and PVC compatibility, never tried it with pressurized plumbing however.
    http://solutions.3m.com/wps/portal/3...be7ZMZSJBQRHgl
    ...another alternative is from Stelmax but it used primarily for PVC coated metal repairs so I can't comment on how well it would work.
    http://www.stelmax.co.uk/pvcfiller.php
    To be honest I would have some PVC bushings made up at a machine shop made out of off the shelf fittings or heavier schedule pipe to fill the gap, this way you can ensure the gap is filled with solid material and standard PVC cement will work properly to bond the components, anything else is a crapshoot.
    Avatar is my pool!
    Apr 2010
    Las Vegas
    173
    Starting the install, unit with adapters on.
    http://s762.photobucket.com/albums/xx26 ... 6fb6ca.pbw
    Apr 2010
    Las Vegas
    173
    Progress has been slow, the temps started to go to 110 deg. And I don't work it that heat I'm doing it the hard way and digging up my pipes to reroute the return line and eliminate many potential 90's that would be needed in the plumbing.
    Next I'm going to look at the circut board to see if I can add a 9v battery backup to the main chip to hold memory during any breif power outages.
    Apr 2010
    Las Vegas
    173
    All done but one adapter leaked and got worse over 2 months so after reading another post but a member here I got a pair of heavy duty rubber coupler by Fernco from Lowe's and she's great. no leaks!
    I'd love to post pics but my camera is 7.1MP so everthings over the .256MP limit.
    Apr 2010
    Las Vegas
    173
    The Lowes SKU is: 23469
    descp is: 2"sheilded coupling flex
    price: $5.79each
    the Homedepot had them from another brand at 8 or 9 dollors ea.
