Results 1 to 10 of 10
Thread: Pool closing in Michigan
    jccams's Avatar
    Dexter, MI
    95
    I am sure this has been covered but here goes anyway.
    I will be closing the pool in the next couple of weeks (PB closes). I have to do it before the leaves start falling or it is a nightmare so the pool will probably still be 65 degrees or so. I used to use the winter Kit by Bioguard before I switched to BBB this year so this will be the first closing doing it this way. My CYA is about 70. Question is what should I add to the pool prior to closing? I have a loop lock cover with 3 mesh panels in it.
    I was planning on adding bleach and I have one bottle of Algaecide left that I thought of adding (never added any this year), it isn't as concentrated as the stuff in the winter kit though. Question is what should I bring the FC level too and how much if any Algaecide should I add? Anything else I should add before covering?
    Thanks
    Jeff
    24,000 gal vinyl Lazy L, 1 hp pump, DE Filter, Pentair 250K heater, Letro Legend pressure side pool sweep
    30,426
    Re: Pool closing in Michigan
    Hi, Jeff,
    I would bring the pool to shock value (around 28ppm) and close. If the algaecide is not polyquat 60, I would not use it.
    jccams's Avatar
    Dexter, MI
    95
    Thanks Dave. It is polyquat 60 so I may add it just for the extra insurance. It does not appear as if I will use it during the swim season anymore.
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    Since I'm in the same state as the OP, I thought I'd add in on the discussion I did use Polyquat 60 last year and opened to a clear, algae free pool. However, the PB suggested not using it this year because upon opening, when shocking the pool, it would kill any algae. Opinions?
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Algaecide is not needed as long as you plan on closing after your water is 60 deg or below and opening before the water reaches 60 deg. Otherwise the poly 60 is good insurance, if you get lazy in the spring and delay opening. I closed last season at shock value and still had a residual 7ppm FC when I opened the pool early may.
    jccams's Avatar
    Dexter, MI
    95
    So there is no danger of the liner fading when you close with such a high chlorine level? In the past I never have checked or had the means to check the exact Chlorine level at closing, maybe the shock in the winter kit brought it up pretty high.
    Apr 2009
    S.E. MI
    570
    Thanks, dmanb2b! I don't think our water will be at nearly 60 by next week, probably more like 75 or so.
    jjcams, I wonder the same thing.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    I can't say for sure on the liner fade...hopefully those with more experience can chime in, but to clarify, I usually bring my FC up to shock and make sure I pass the overnight FC test and close the afternoon after I have passed the ONFC test...by the afternoon, my water falls 4-6ppm below shock level and I wrap 'er up. We have a dark blue liner and no fade so far.
    Then again, if I think about what I used to toss in the pool for closing before finding TFP and listening to my local pool shop....I'm surprised my past pool liner ever survived a winter ...few bags of shock, winterizing tabs??, algaecide and hope for the best
    Obviously though if you have an older liner or one that already is fading...hold a high FC for 4-5 months won't help things.
    Apr 2009
    S.E. MI
    570
    Thanks so much for the reply. Our liner is going on 8 years old. Although it still looks really good, there is one spot in the shallow end on the wall between the returns that is getting wrinkles. I'm nervous about shocking because the last time I shocked, it took a good week for the FC to drop from shock level to a high level. We're closing a week from today.
    Do you know anything about non-chlorine shock? Is this something I should consider, or should I just stick with chlorine?
    I'm curious, is it necessary to shock, or can I just raise the FC level a bit, let's say from 5 to 8?
    jccams's Avatar
    Dexter, MI
    95
    Because I have a high CYA level(70-80) I raise my FC to about 10 every night to prevent falling below 5-6 during the day. Our liner is also 8 years old and in pretty good shape. Haven't noticed any fade although if it happens a little every year I may never notice it until it is replaced. I am closing the 29th and will raise the pool to shock level over the week-end prior to do the overnight test and let it fall back to a little below shock level before closing. I am also going to add the Algaecide I have not used this season just for added insurance and hope for the best. As mentioned with all the **** I used to put in it this can't be any worse.
