Results 1 to 7 of 7
Thread: Whats the Best Automatic Pump for Winter Cover?
    Hi,
    I am looking for the best automatic pump for the top of my solid winter cover. I have a large amount of pine needles due to the Norway Spruces lining the side of the pool (I don't want to cut them down). Also, I live in northern NJ so the water on top (mixed with leaves and debris) freezes. So the pump needs to be able to handle both debris and not get damaged when it freezes. Not the perfect pool location, but its what I have. I've tried to find reviews of pumps but they are mixed. Who here has good experience with a particular pump that would work in my conditions?
    Regards,
    Ken
    20K SWG Pool/Hayward Tristar/Pentair Intellibrite LED
    South Central NJ
    3,192
    Re: Whats the Best Automatic Pump for Winter Cover?
    This is the make and model I sell to my customers. The web site and I have no affiliation.
    Scott
    http://www.poolproducts.com/SPP/product ... f_id=A5028
    Owner of - PoolGuyNJ LLC
    22,551
    Welcome to TFP.
    I would trust what Scott says. Rule has been making bilge pumps forever and make a good unit.
    You do need to check the unit once in a while to make sure something isn't hanging up the [s:28v6hcqy]float[/s:28v6hcqy] unit.
    Search around for a good price.
    South Central NJ
    3,192
    The Rule doesn't have a float. The tests to see if there is water every few minutes. If the current load is increased from normal, it assumes the load is water and stays on. If no increase in current from the known no-load state, it turns itself off.
    Scott
    22,551
    Thanks for correcting me Scott. I edited my post to say what I really meant.
    Mar 2007
    San Rafael, CA USA
    12,082
    I have a Rule 1800 and it works great. The first version of it I had used a different bottom section that cracked and the pipe nozzle attachment also cracked but instead of replacing the nozzle and fixing it myself, I just got the newer version of the pump and bottom attachment and it's been fine so far. Note that if you get a lot of leaves or other material, the entrances to the pump (i.e. that bottom blue plastic section) can get clogged so you may need to periodically remove such debris for the pump to properly remove water.
    Jun 2007
    New Jersey
    653
    I co-sign on the Rule. I went through three Little Giants my first two winters. As you know, in NNJ we get freeze followed by rain, and then back to freeze again all through the winter. So the pump has to stay out there to be useful. No bringing it in once you get to December as you would in colder places. The Rule electronics are designed to deal with this. The pump only runs if it is actually able to pump water. So if the hose is frozen downstream, it stays off. This was what killed the Little Giants.
    I put the whole pump in one of those mesh bags they sell for camping and cinch the neck up on the hose and power cord. It keeps the leaves from blocking the ports. You just have to pick the pump up once in a while and shake it off and put it down in a new place, maybe 3 times a winter. That's MUCH easier than taking the strainer/base off and cleaning it. Also, Rule has a three-year guarantee, ask what Little Giant has....
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
