Results 1 to 7 of 7
Thread: Hey everybody
    Sep 2010
    Noblesville, IN
    104
    Hey everybody
    Just signing in as a noob. We had a 16 x 32 vinyl pool put in last month and are getting te final stages of landscaping done. I'm sureto have a lot of questons because this is our first pool and we are old people. From what I've read so far I may need a degree in chemistry....
    16 x 32 15300 gal. IG Vinyl Jandy pump, Jandy sand filter, Paramount circulation system, Automatic pool cover.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Hey everybody
    Welcome to the forum
    ....we are old people. From what I've read so far I may need a degree in chemistry......
    nah, even us old-er people can do it
    You're done SLAMing when:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Hey everybody
    Quote Originally Posted by HoleInOne
    Not at all. If you can follow the directions on a cake mix or a box of hamburger helper, you can maintain a perfect pool.
    I'm hoping you've read Pool School. I suspect you've started, based on your comment. Do you find yourself staring at the screen with your jaw hanging open, unable to move for minutes, until you realize you haven't got a clue what you just read? Don't worry, once you start testing and treating and seeing the results, it will suddenly come into focus.
    Do yourself a huge favor and order up a good test kit now. I recommend the TF100 and the speedstir. There's an article about it in Pool School.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Hey everybody
    Welcome to TFP!
    Congrats on your hole in one (I presume)! I hit one to six inches my very first time playing golf, but haven't come that close since.
    Re: Hey everybody
    Don't worry about the chemistry, the Pool Calculator will do the hard stuff. Test the water daily at first and keep records of tests and chemicals added.
    In the beginning, check here before you do much of anything, just to be sure you have the numbers correct. Pretty soon it will all be routine, something like a cup or 2 of this, something like a jug of that, and test the other things weekly or monthly.
    Pisces's Avatar
    Jun 2008
    League City, Texas
    273
    Re: Hey everybody
    Welcome! You can definitely learn this stuff...I did..a year and a half ago for my new (and first) pool. Best thing I've done. It may seem overwhelming at first, but reading and re-reading some to get familiar with it all, then testing with a good kit, and keeping a logbook will make you a pro in no time. I saw it as something "fun" to learn, and it was...it's very gratifying to see the good results! The great majority is very simple basic stuff when you break it all down into steps. No degree needed. Plus, you have plenty of TFP'ers to hold your hand through the learning process and beyond. Happy pool ownership!
    7,000 gal. IG gunite, SWG, PebbleSheen interior finish-Aqua Blue, 8' vanishing edge raised 16-jet overspill spa, 2 12" waterfalls, tan shelf with bubbler.
    Pentair equipment: Easy Touch 8, Intellichlor IC-40, Intelliflo VF 3050, 2.5 hp Whisperflo spa pump, 1 hp Whisperflo water feature pump, Quad 100 DE filter, Master Temp 400 heater, Legend Platinum Cleaner (3/4 hp pump). Autofill, TF-100 Test Kit w/salt and borate strips.
    Pisces Pool Build
    Sep 2010
    Noblesville, IN
    104
    Re: Hey everybody
    Quote Originally Posted by Melt In The Sun
    Welcome to TFP!
    Thanks. Yep got one on the seventeenth hole and celebrated the rest of the day. I was signing hats, shirts, anything anybody had on. I think at one time they counted 35 empty glasses that held crown n water sitting on the table. I can't remember how many I bought but it was definetly a good time.
