Thread: Newbee
    Newbee
    New to the pool school! It seems like the place to be! New pool this June. I have not shocked after pool company set it up and got swim ready. OTO test and PH have always been fine. water sparkles. Do I leave well enough alone? Just ordered a Taylor K 2006 kit before I found this sight for CYA testing etc. When it arrives what is the most important test to perform. Sorry for the dumb questions.
    Thanks Mike
    Mike W. Mesquite NV,
    10400 Gal, IG, Plaster over Gunite, Jandy CV460 2HP, Flow Rate 150 GPM
    APP. 10150 Gal, 24' x 14' IG, Plaster over Gunite, Jandy CV460 (cartridge) 2HP, Flow Rate 150 GPM
    30,432
    Re: Newbee
    Hey, Mike,
    Welcome to the forum!!! Sounds like you have been taking great care of your pool.
    It would be a good idea to perform ALL the tests in the K2006 (it has CYA testing and is a great kit) and post them up here on the forum.
    You'll probably be encouraged to do a little tweaking but crystal clear water is the goal and you're there!!
    Re: Newbee
    Thanks Dave!!
    Re: Newbee
    It is good practice to log the results of your tests. Keeping records of test results and the chemicals you add, what and how much and when, can tip you off to slow changes that need attention.
    Re: Newbee
    Thanks
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Newbee
    All of them are important. Especially when you're just starting to use the kit - you want to establish a baseline. Then, when TA suddenly leaps and you haven't added anything, you'll realize there's something wrong with the test, not the pool. Just as an example. It happened to me the other day, when I opened a new bottle of R-009. And I knew better. But I digress.
    You need all the numbers to enter into Pool Calculator, so it can calculate CSI, which is important to prevent concrete decay or scaling.
