Thread: Question about cell longevity
    I have the larger Jandy Purelink(Aquapure) and was wondering if there is any difference in projected cell longevity if I run the cell at 80% for 6 hours vs. 40% for 12 hours.
    Thanks in advance.
    20k inground, Heyward Sand Filter, Compupool Salt Generator, Blue Pearl Robotic Cleaner
    mas985's Avatar
    Pleasanton, CA
    11,737
    Theoretically, it shouldn't make a difference since at both settings, you are really only running it 4.8 hours per day. I think the settings work much like the Aqualogic where they are really duty cycles which turn the unit on and off over a set period of time.
    Mark
    I split off the rather technical discussion of how amps and volts and bipolar cells all interact inside of a SWG to this thread in the Advanced Chemistry section.
