Thread: Do I need to cut the ladder?
    Jul 2010
    Mickleton, NJ
    229
    We have the ladder pictured below. We are currently installing a paver patio with walk way up to the pool. The Walkway will make the ground outside of the pool considerable higher then the bottom of the pool. So we are thinking the best option is to cut the ladder steps on the outside of the pool to shorten them. Has anyone else had to do this? Is there something else we can do instead?
    I guess I'm just concerned about getting it right or should I just see if the pool store will take the ladder back and then purchase something else? This is the ladder that came with the pool and I do really like it. We've had it for about six weeks now.
    http://www.nextag.com/Confer-Plastics-R ... rices-html
    Currently Pooless
    Former Pool:Buster Crabbe resin and steel 30'x15' oval 52" ABG pool Pentair sand dollar filter 1.5 Pentair Dynamo pump13,500 gallons
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Do I need to cut the ladder?
    You could ask the pool store what they think, but I don't see anything wrong with cutting the ladder.
