Thread: I want to use the calculator to tell me how much shock to ad
    Quote Originally Posted by sbelgrave
    Thanks alot. Very helpful
    I want to use the calculator to tell me how much shock to add to my pool. I inserted all of the data parameters, and it reads "17." I believe that is the ppm of FC it wants me to raise the level to. Correct? But, I do not see how many pounds of shock I should add to achieve this level.
    Jun 2010
    San Antonio
    424
    Re: The Pool Calculator
    If you put the shock level in the Target Column and your current level in the Now Column at the very to where it says FC you can read to the right the amount you need to add to bring your FC to the target level. You need to have the correct size pool filled in at the top and you need the correct amount of CYA in the Now Column where it says CYA in order to get a correct calculation. Hope this helps. If you want, do the calculations, tell us what your numbers are and one us here can verify your calculations.
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
