Thread: I covered my pool today
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    It's been hot the last few days, which got the pool up to 81 yesterday, from a low of 76 before sunrise. But it's supposed to cool down some this week. I decided it was finally time to unwrap the blue bubble cover I bought nearly a year ago. It's supposed to heat the pool a little, and insulate, so I figure I can stretch the swim season a bit this way.
    So I unrolled it and dragged it around some then weighted the corners with loose bricks and trimmed it roughly to size. There were actually instructions rolled up inside that say let it float two days before trimming. So I will. There's a few wrinkles yet that should smooth out.
    Anything else I should know about using a cover?
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    Re: I covered my pool today
    I learned that IF one gets algae, float the cover in the shock water as the algae is probably lodged in the spaces between the tiny little air bubbles. I'm just sayin'...it is highly unlikely that anyone who follows the BBB system will get algae, but one never knows...
    2005 Dimension One Venture model 370 gal. hot tub. We'll be using the TFP method to keep it clean and ready to use!
    TFP - The Finest Phorum on the Net!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Better a little too small than a little too big when you trim it. Anything not sitting on the water can get picked up by the wind.
    Jan 2010
    Central Valley, CA
    233
    I need to break out my solar cover and had the same questions. Thanks. Poolstore gave me a 16x32 (probably by mistake) instead of a 24x12 so I have a lot of trimming. Store is an hour away and there were several issues so didn't seem worth the effort to swap when I can trim although I hate the waste.
    Garden Leisure Voyager 12x24 AGP, 7500 Gallons, Hayward Power Flo Matrix 1 HP pump, dual speed, Hayward XStream Cartridge Filter, 120 GPM,
    Richard320's Avatar
    Jan 2010
    19,004
    Quote Originally Posted by Sportsman
    I'm saving my trimmings. It's good stuff to disguise presents at Christmas.
    no-mas's Avatar
    Jun 2008
    FL
    405
    Not sure how large your pool is, or if you're using a reel, but you may wish to consider cutting the cover in half to make it easier to manage. Those in windy environments may disagree, since there is an extra "edge" for the wind to catch, however splitting my cover made it much easier to remove, store and deploy.
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
