Thread: testing while shocking
    May 2009
    Austin, Texas
    77
    I've read that testing pH is not possible while shocking. Are there any other tests that are influenced or made invalid by shocking that we should know about? Can we trust every other test while shocking besides pH?
    Mike
    25k IG w/ Pebble Sheen +8' diameter spa w/spillway w/ Hayward ProLogic +T-CELL-15 SWCG
    Cartridge Filter and Gas Heater on Hayward Pump SPX3215X20Z1PE (w/ 2.00 HP, 1.10 SF motor)
    +separate waterfall on Hayward Pump SPX3210Z1PE (w/ 1.00 HP, 1.25 SF motor)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: testing while shocking
    pH will llikely be off a little. TA will go blue-to-yellow instead of green-to-red. Seems like CH is also very pale and hard to read when I've done it with high FC.
    I think the chlorine bleaches out the dyes used in the indicators.
