Results 1 to 18 of 18
Thread: Deck Jecks Not Going High Enough
    They are installing a pool, inground, with 6 Deck jets. The pool holds approximately 30,000 gallons, and has a 2 HP pump. The deck jets dont go very high at all. DOes anyone know how to fix it???
    My online plumbing
    30,419
    Re: Deck Jecks Not Going High Enough
    Is there a dedicated line going to the deck jets or is some of the returning water diverted to other outlets in the pool?
    I have a 2HP pump which feeds 2 returns, a boulder waterfall and 2 deck jets. I find that if I direct all the water to just the deck jets, it shoots high enough to launch the water stream out of the pool and over the fence (looks like Old Faithful!!). But when I want the waterfall and deck jets running together, I have to nearly completely shut off the 2 returns in order to get enough water output directed to those features.
    My guess is that with 6 deck jets, the demand is going to be very high and so if your 2HP pump is trying to feed any other returns or water features, you may not have enough power.
    20'6" X 38'6" (609 sqft)
    22,500 gal gunite/plaster IGP
    DE filter, Jandy 2HP pump, Nature2 Sanitizer (removed cartridge!)
    Raypak 39.9K BTU gas heater
    2 ColorLogic lights, Maytronics Dolphin pool cleaner
    Jul 2007
    Suwanee, GA
    528
    Tim may claim to be a newbie but his advice sounds good. Dave is also on to something about some of the water being returned to the pool unseen. How about some pictures, both of the fountains and of the pool equipment. Also time how long it takes a jet to fill a 5 gal bucket.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,054
    I have a sheer descent, one deck jet and mermaid statute water feature and an IG bubbler. I have to turn off completely my returns in order to run all the water features, however I cannot open the deck jet and mermaid feature fully as is sprays too far. Hope this helps
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    WOw! Thanks for all these responses. I will get some pictures up shortly for yall. It does not run off a separate pump. To turn on the deck jets, (forgive me I am new to this pool stuff, so I will explain it the best I can), you have to turn this knob that slows down the jets in the pool. The 6 deck jets are run with a 3/4 inch PVC, so I am wondering if we need bigger PVC? The pool guy said he will put in a 1 1/2 inch PVC that will run to all 6 deck jets, and that should fix it. Let me post pictures of all that too. Wow, you guys are all so helpful. One second....
    16 x 32 15300 gal. IG Vinyl Jandy pump, Jandy sand filter, Paramount circulation system, Automatic pool cover.
    (new to pool = April 12345) I lost the info for my first username so had to use this one.
    does anyone know how to post pictures? I took pictures of the deck jets and the plumbing but dont know how to post them ?
    Ok, I figured it ok. FOR PICTURES OF THE PLUMBING AND DECK JETS, see below I have a 30 inch filter, 2 HP Pentair and a separate booster pump that just runs the POlaris. The pool is a Roman "L", 43 inches long, 26 inches on the shallow wall, and 18 inches wide on the deep end, 10-foot roman steps. They said probably about 28,000 gallons. The pool is plumbed with 1 1/2 inch PVC (it appears). The pool contractor has not completed the work because we are unhappy with the deck jets. Should we ask for a separate pump for the deck jets? The pool guy says that if he changes the horizontal PVC that runs along the top of the outputs to the deck jets from 3/4 inch to 1 1/2 inch, we will get the pressure we need.
    Someone please help!!! I feel as if I am being tricked. The pool contractor is waiting on his last draw, and I dont intend to give it to him until the work is done RIGHT. Thanks!!!
    By apriljo at 2010-09-12
    Jul 2007
    Suwanee, GA
    528
    Why would anyone choose to use a 3/4 in line feeding 6 x 3/4 inch lines. Also, with a 2 hp pump, it would have been nice if he used 2" pipes. You can see he used reducers to and from the pump and the filter.
    What happens when you close the valve going back to the pool returns a bit? That is the one after the T going to the jets? that should send increase the pressure to the jets.
    I think the deck jet manifold needs a 1 1/2 inch pipe. It's the only way you'd get enough water through there if you choose to close the return valve and have all the water directed to the jets.
    Gary
    Hi Crabboy!
    Yes, thats what he is talking about doing. (Replacing the line that feeds the deckjets with a 1 1/2 inch PVC). When he built the pool, he first put a 1.5HP pump, so I guess he plumbed it with 1 1/2 inch PVC based on that?
    If we turn off the returns completely (and send all water to the jets), it still looks like the pictures (not enough).
    I guess the "manifold" you are referring to is that horizontal pipe feeding all 6 deck jets? (Bear with me, I am new to all this )
    Also, what are reducers? Are they bad or good? Is it something I should have him change?
    Jul 2007
    Suwanee, GA
    528
    Does the filter pressure change if you switch from the returns to the deck jets?
    The filter looks like it takes 2" fittings, you PB had to reduce these to 1 1/2" pipes, hence the reducers. They are necessary to use the smaller pipe as they did. I think the pump fittings can take either 1 1/2 or 2.
    I would have him replace the pipe that runs across the top ( manifold ) and that should increase the flow quite a bit. I don't know how he though that would work in the first place. Also, now that he set himself up for attacks on his plumping work, why did he feel the need to space the deck jet return lines so far apart. I think a few inches would be better than this. That long stretch is more likely to get kicked, bumped, hit with the mower, etc...
    Gary
    I just can't wait for this job to be over with. This issue, combinedwith the bleach spot I think his chemicals left in the bottom of my pool, is enough to drive anyone crazy!!! I posted a question about the bleach spot on this website and got great responses. I will definitely support this website!
    So only pipe for him to replace is manifold above deck jets? Got it !
    I will see about the pressure issue tomorrow and will post what I learn.
    Thanks again.
    WOW! So the pool guy replaced the manifold to a 1 1/2 inch PVC and PRESTO!!!! They shoot higher than I ever thought! Wow, I can't thank all of you enough.
    4JawChuck's Avatar
    Jun 2010
    Winnipeg, Manitoba, Canada
    223
    Got to make you wonder why anyone who knows anything about plumbing would build a header that feeds 6 - 3/4" lines out of 3/4" line?
    Kinda scary!
    55 Kilolitre in-ground 18'X36' vinyl lined kidney shape, 1HP pump, Jacuzzi 250lb sand filter, RayPak Delta T 200K BTU natural gas heater. New PoolWerks "Blue Diffusion" liner on May 26th-2011
    Avatar is my pool!
