Results 1 to 10 of 10
Thread: First time user of TF-100 Test Kit and Magnetic Stirrer
    Hi,
    I have a Vinyl pool that is 18x36 (8 foot deep end), it has been aprox 1 year since the construction.
    I have a Sand Filter, 1.5 HP pump, Aqua Logic P4 system with Aqua Logic Salt System.
    I ordered the Test kit based on the fact that I often hear the Pool store kids don't always get it right.
    I'm just not sure where to start now, what exactly should I be testing and how often, are there detailed instructions for someone that has never done this before and isn't super comfortable.
    Also, My inground Stairs have Rust like spots all over them, I was told it could be copper and I need to test for it. Am I able to do that with the TF-100? if not then what do I do?
    I also have a lot of black grease like substance in the skimmer that I don't know how to get rid of.
    Thank you for any feedback and assistance you can provide.
    18' x 36" Ovalish 80,000 Litre Vinyl IGP. 2 speed 1HP Hayward pump SP2607X102S. 300 Pound Sand Filter. Summit Sum5 Heat Pump, Goldline Controls Aqua Logic P4 System, T-CELL-15 SWG, Aqua Pod Remote Control, Pentair 7845xx02 light.
    TF-100 Test Kit, SpeedStir Stirrer, Pool Chemist in training.
    Mar 2010
    Spring, TX
    1,082
    Re: First time user of TF-100 Test Kit and Magnetic Stirrer
    I can answer the part about the instructions. I had never owned a pool either and was worried about what I was getting into. The instructions that come with the kit make it very easy to do. It has step by step instructions on exactly what to do. Most of the testing involved filling up a tube with pool water to a certain ml size and then using the different chemicals that are labled and just droping the amount of drops it ask for in that order and mixing it. It is very easy to do even for someone who has never done it before.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    22,551
    Use the instructions that came with the kit. If you have questions there is a sticky at the top of this section that has extended testing instructions. There's also a set of instructions on one page.
    To get rid of the scum line you can use Mr.Clean Magic Erasers. To keep them away get some scum balls they absorb the oils, etc before they deposit on the surfaces.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    As for the stains, if they look like rust they are probably rust, not copper. A picture would help! The TF-100 doesn't do tests for metals, but your local pool store may be able to.
    Mar 2010
    Spring, TX
    1,082
    If you do get your water tested at the pool store do not buy anything then. Come here post your results and the people here will tell you what you need to get.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    You made some good choices, there.
    Initially, I was testing the water every day. I was actively trying to reduce TA. Then, with pumpouts and rainwater dilution, it needed a lot of adjustment. Now, I test every couple days, or after I've done something major - like pumping out and refilling or aggressively reducing TA just before leaving for vacation.
    In a few weeks, it will become very routine, like making coffee. You'll probably know, before you test, what numbers you will see, and how much of what you need to add to make it all perfect.
    That speedstir is the best, especially for the CH test, which takes a loooooong time if you have real hard water.
    Thansk for the replies, I plan to get over my fear and just sit down with all this stuff and read through the instructions.
    Typically after you get everythign balanced correctly, what percentage are you able to bring your Salt Water Generator to?
    My Aqualogic is set to 50% and I run my pump 12 hours from 6am to 6pm and when I go to the pool store they usually tell me that my chlorine is just right so I've always left it there.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    As far as what you should be testing (and how often) check out pool-school/basic_pool_care_schedule.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Oct 2007
    Valrico, FL
    542
    Chlroine demand varies somewhat between pool to pool. However it is usually between 1 to 3 ppm per day. I have attached a spreadsheet that may allow you to calculate your chlorine demand. Another test is to perform the over night FC loss test. I believe it is explained in the pool school link locate at the top of the web page.
    Attached Files Attached Files
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Hey Rockstead-- ever find out what the black greasy stuff is on the skimmer walls??? I have the same thing and when I touch it to empty the basket it is extremely hard to get off of my hands. Let me know if you have a solution. Thanks.
