Thread: Unidentified metals in solution
    solarboy's Avatar
    Aug 2010
    Europe
    337
    I'm working on a pool in an area known for it's high iron content in the well water. The pool is filled with this well water and there is no option for another source. I have been dealing with this quite successfully by shocking, flocculanting and vacumming to waste. My question is this; why is the water green? I know it's not algae. I shocked the pool and then added more water.It turned jade green but not murky. I'm thinking copper (the largest copper mine in Europe is 30 miles away) due to the green colour. I also think the water is full of iron and manganese. The geology is schist.
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
    Dec 2009
    Central Massachusetts
    2,690
    Re: Unidentified metals in solution
    Whats the color of the pool plaster/vinyl? Blue or slightly blue backgrounds will mix with the yellowish iron color and make the water look green.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Copper in the water plus shocking will turn the water a bright clear transparent emerald green. Iron plus shocking will turn the water clear transparent yellow, which often looks green when the pool surface is blue, not as bright a green as copper gives you.
    solarboy's Avatar
    Aug 2010
    Europe
    337
    Hi, thanks for your replies. The pool is tiled with beige glass mosaic tiles. I think this is over and above what you'd expect naturally. After what you said I'd guess it's a mixture of copper and Iron. I'll try and get some pictures but my cameraphone is well, a cameraphone.
