Thread: Help with cleaning gravel/rocks/conccrete,etc out of pool
    Jul 2008
    Flintstone, GA USA
    112
    Well I have a nightmare. I am having my pool remodeled and the contractor told me that he would float plastic over my pool to catch anything such as above.
    Well he did not and now I have concrete chips rocks fiberglass and who knows what in my pool. He said he could clean it out with my regular pool pole filter. I refused to let him use my polaris automatic cleaner.
    Now I don't know about doing this because I don't want the smaller grit and stones going by my basket and through my piping and pump.
    What would you suggest would be a proper way to handle this? I thought about putting fiberglass type screening that is used for window screens either under my skimmer basket or maybe line my skimmer basket with the screening that would catch smaller particles.
    Is this a good idea?
    Would this type of material going through my pipes, diverter valve and PUMP hurt anything?
    Your suggestions would be helpful.
    Tom
    18 x 36 Grecian Polynesian Fiberglass Walls with Concrete bottom - 3 ft to 9 1/2 ft. deep -
    Hayward Variable Speed Super Pump SP2600VS 1 1/2 True HP,Hayward sand filter S200, and Hayward auto clorinator. Hayward 250,000 natural gas heater. PoolKeeper automatic water leveler. Loop Loc Ultra Solid Safety Cover. Hayward Color Logic 12 volt light. Dual Pool Deck Jets.
    Polaris 380 auto cleaner. Trouble Free Test Kit TF-100.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Help with cleaning gravel/rocks/conccrete,etc out of pool
    The holes in the pump strainer basket aren't going to let anything very large get to the pump. If you are concerned, you can use a skimmer sock on your skimmer basket while vacuuming. I expect you'd have to stop and clean the sock pretty frequently, but it won't let anything of any significance get through.
    Jul 2008
    Flintstone, GA USA
    112
    Thanks for this information. I had rather have to clean out the skimmer basket more often than to have any problems later.
    Tom
    Tom
    If you're going to use a skimmer sock, pick up some inexpensive knee high stockings - they do the trick just as well and much cheaper!!
    20'6" X 38'6" (609 sqft)
    22,500 gal gunite/plaster IGP
    DE filter, Jandy 2HP pump, Nature2 Sanitizer (removed cartridge!)
    Raypak 39.9K BTU gas heater
    2 ColorLogic lights, Maytronics Dolphin pool cleaner
    Aug 2009
    North Central Texas
    1,358
    If it were my pool I would strongly request he use a trash pump, even if he has to rent one, preferably a setup that has its own filter and direct the water back into the pool. If using a trash pump without a filter then water could be run back to the pool using a big Slime Bag.
    Any skimmer sock is going to load extremely fast. A women's hoisery may not be strong enough and tear easily. Also, in vacuuming, I would think an inline leaf canister would be needed. If you have one, and he uses your vacuum and hose and leaf catcher then get in writing that he will purchase you a new leaf canister bag when the job is finished.
    That's just me but I've had lots of experience, over the years, with my pool and excess debris of different sorts. I purchased my own trash pump years ago because I didn't want certain stuff going through my system.
    I would also be concerned about scratching the pool unless the vacuuming was done very gently with the exact proper vac head.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
