Results 1 to 10 of 10
Thread: pump size for replacement
    Jan 2010
    Central Valley, CA
    233
    I currently have a single speed Hayward 1.5 HP Power Flo Matrix with X-Stream filter. With CA utility rates and reading this site, I know I need to go to a 2 speed. I need to adjust sig, pool seems to be approx. 7500 gallons based on pool calculator and effects from chemicals added.
    I was looking for a 1.5 hp 2 speed but Hayward makes a 1 HP 2 speed in the same series. Is this sufficient for this pool for filtering and vacuuming? I presume it is but want feedback before plunking down $280.
    Garden Leisure Voyager 12x24 AGP, 7500 Gallons, Hayward Power Flo Matrix 1 HP pump, dual speed, Hayward XStream Cartridge Filter, 120 GPM,
    South Central NJ
    3,192
    Re: pump size for replacement
    Yes, it is.
    Scott
    Owner of - PoolGuyNJ LLC
    22,553
    A 1hp 2-speed is more than enough for that pool. A 3/4 hp 2-speed would do it, but they're hard to find.
    mas985's Avatar
    Pleasanton, CA
    11,741
    The Whisperflo WFDS-3 is a full rated 3/4 HP two speed and the WFDS-24 is 1 HP uprated two speed which is basically the same as the WFDS-3. Both are pretty powerful and efficient plus have the added benefit of low speed.
    Mark
    Jan 2010
    Central Valley, CA
    233
    Thanks to all. Does it matter if the pump matches the filter? Not married to Hayward if it doesn't matter. The Power-Flo Matrix does easily convert to side discharge for easy hookup to the filter.
    Also, at .40 marginal cost for electricity, is common wisdom that is well worth switching out a fully functioning pump? I like the peace of mind that I'm using less electricity especially if I have to shock and run the pump continuously.
    I bought my whole setup as a display model closeout so there were no options on changing the pump at time of purchase.
    mas985's Avatar
    Pleasanton, CA
    11,741
    No the pump doesn't have to match the filter it just needs to be sized properly for the filter.
    Another option if your pump is still in good condition, would be to just replace the motor with a two speed plus a new seal kit. This can be close to half the cost of a new pump. Of course, you have to comfortable doing the work yourself or finding someone who won't charge an arm and a leg.
    Mark
    Jan 2010
    Central Valley, CA
    233
    I'm reasonably handy but don't mess with electrical much. I can change install a ceiling fan or change a receptacle. Much more than that I haven't done. I did look online for motors but the prices I found were almost the same as the pump on Amazon.
    http://www.amazon.com/Hayward-SP15922S- ... X3AQC03FAK
    The filter is 150 sq ft, model CC1500, 120 gpm. How do I find out if that's fine for 3/4 hp or 1 hp two speed?
    Thanks for all the help.
    edit: maybe I'm looking in the wrong places for just a motor.
    South Central NJ
    3,192
    If you can wire a fan, you can wire a pump. Just have a multimeter handy so you will know whether you have 120 or 240 going to the pump.
    If you have an above ground pool, the Pentair OptiFlo pumps are 120 and can come equipped with either the twist lock or standard plug. Check the pricing for them as well since pumps for above ground pump tend to be lower cost. Don't use an above ground pump on an in ground pool. The designs are different in some very important areas.
    Scott
    Jan 2010
    Central Valley, CA
    233
    Thanks. I'm 120, 3 prong outlet, and above ground pool. I have a long weekend so I can do some research on options. I hadn't looked at anything but the Haywards.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Quote Originally Posted by Sportsman
    That pump should be fine for the filter and your right, it would be hard to find just a motor at much below that cost. I was thinking in-ground when I wrote that.
    Mark
