Results 1 to 16 of 16
Thread: Installation of Loop Loc cover anchors
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Hello all~~
    I am posting this in the Under Construction forum because I wish to attract the opinion of builder/contractor folk as well as those members who have recently gone through a pool build.
    Earlier this year we had a complete renovation done on our inground concrete pool. All payments are made. The builder has yet to install the Loop Loc pop-up anchors for our new cover.
    Our pool is surrounded by a new Belgard paver patio. The pavers are roughly 4 inches thick; they sit on their sand base, which is over a substantial extra-deep sub-base. Polymeric sand is between the pavers. The paver sizes are roughly 8"x12", 8"x8", and 4"x8", in a mixed pattern, including many much smaller pieces and slivers cut to make curves and such.
    The following is not detailed in our contract: DH and I understood, from conversations with the builder, months ago, that deep holes are drilled (maybe 9 or 12 inches) for every anchor, a long thin pipe goes into each hole and that the brass anchors then sit in the long thin piping giving it a strong position down to the sub-base.
    Now that it is time to do the work, we understand through the installation subcontractor/pool care company that these deep holes with the piping will not be done---that short holes only the depth of the brass anchors will be drilled and the anchors will be attached only to the paver itself--no anchoring will go below the paver into the sub-base. I can understand doing short holes in a solid concrete surround or sidewalk, but with pavers? I have visions of the Loop Loc cover pulling the pavers up, if not right away then maybe next year or the year after.
    I phoned Loop Loc, but their representative would not offer a clear opinion on my situation.
    I would be grateful for your opinions and experience.
    Thank you very much!
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
    Dec 2009
    Central Massachusetts
    2,690
    Re: Installation of Loop Loc cover anchors
    Call the builder. Do not allow a subcontractor to drill into the pavers and insert the 4 inch brass anchors that way. The proper way is what was originally described to you. Furthermore, the holes should not be drilled into the middle of the paver at all. The holes are drilled between the pavers and the pipe is sunk into the sub base.
    If they suggest that drilling into the pavers is the only way they will do it, find another contractor that knows what they are doing.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Aug 2007
    near the swamp
    806
    sounds like a lawsuit waiting to happen
    Dec 2009
    2,690
    Not sure about a law suit, but it isn't the way to install a loop-loc on a paver deck, thats for sure.
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    DO NOT let them drill into your pavers unless they are installing paver tubes.. PERIOD
    This is from loop locs site
    If we have a paver/brick deck can we use a Loop-Loc Cover?
    Absolutely! Loop-Loc's anchor-in-pipe installation is the perfect application for paver/brick decks. The pipe holds the anchors firmly into place allowing the cover the remain taut all winter long. No wear and tear on the deck, will not pull or ruin pavers/bricks whatsoever. For additional information on anchor-in-pipe please contact your Loop-Loc dealer or our customer support department at 800-562-5667.
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
    Dec 2009
    2,690
    Quote Originally Posted by Heckpools
    Even then, I cant stress enough, drill BETWEEN the pavers in the joints, not though a single brick itself.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Pavers will bulge and loosen over a few years. Definetly listen to the posted advice
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Anchors need to be far enough away from the pool edge!!
    Hello All~~
    After being away on business for a few weeks, I spent the day in the back yard raking leaves and generally cleaning around the covered pool. It occurred to me that I never came back to tell you how the Loop-Loc story ended. Once again, I hope that someone out there benefits from this tidbit of knowledge that I learned too late.
    The builder did come back sometime in October I think it was, and installed the pop-up pins after drilling down deep and inserting those tubes. He put the anchor pins right in the middle of the pavers. So far nothing bad seems to have resulted--no cracked pavers, no pavers pulling up.
    However--here is the lesson to be learned: the anchor pins are not far enough away from the pool! The cover sags even though all of the straps are as tight as they can go. Had he thought about this a bit (or had I been there in person to suggest it), he would have realized that his spacing was poor. When leaves collect on the cover, the entire center of the cover is in the water. He should have let out the slack in the straps, determined a generous distance for the anchors, and then the cover could be snugged up out of the water.
    Our old Loop-Loc cover was as tight as a drum--keeping it clean was literally a breeze; the wind would blow most of the leaves off.
    Lana
    Dec 2009
    2,690
    The buckles are as far up as they can go? Normally, guys that do loop loc installs know how far out to go from the edge of the pool. Generally, you go out far enough so that about half of the strap is used. That way you can adjust tighter or looser once you get the cover attached on each end.
    Did you pay them yet?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Wow. Hard to believe a pro would do that. IIRC mine said at least 18", and I did that with good results. Sounds like your installer wasn't very experienced.
    Dec 2009
    2,690
    Yea, mine are about 18-20", give or take.
    Dec 2010
    franklin lakes, nj
    3
    I've been installing Meyco Products branded safety covers for ten years... I drill 36" from inside of coping as a rule. The cover will stretch over the first season and for the rest of it's life. It's also important that the water level is maintained over the winter to both support accumulating snow/ice and to maintain the safety feature of the cover which is the elimination of drowning risk.
    10 year technician-
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    Quote Originally Posted by nglessner
    Ive always done 32, ill give that 36 a try on my next cover.
    COMPANY INFO BELOW
    Jul 2012
    Cary, NC (Raleigh)
    69
    Saw this post and wanted to ask a follow-up question to the forum. I'm at the design phase of my pool but wanted to ensure I'm placing enough concrete decking around the perimeter to allow for safety cover. On the area's of the pool where I won't be placing furniture and want to maintain more yard I like the look of minimal decking next to grass and wanted to only do a 18" wide decking in those area's.
    Is there a minimum deck width needed to install a safety cover like the Loop-Loc? Thanks.
    18x30 Freeform In-ground Vinyl Lined. 11,500 gallons.
    4 returns, 2 skimmers, 2 main drains.
    Hayward TriStar 1hp 2-Speed Pump. Hayward S244T Filter.Hayward Goldline Panel + SWG.
    Polaris 280 cleaner. AquaComfort 75k BTU Heatpump
    TF-100
    Qwaxalot's Avatar
    Jun 2012
    439
    Theoretically, you can install a safety cover into dirt, using the 15" anchor pipes discussed in this thread. However if more than 30% of the perimeter is anchored this way, it will no longer be considered a "safety" cover.
    An 18" deck width is pretty marginal, although it could be done (assuming it's concrete). Consider though that 18" is not very convenient to move around on when performing maintenance.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    I am going to install a Loop Loc cover on my pool at the end of the season. A few questions: am I better off getting a solid cover with the built in drain vent or the newer type mesh covers that supposedly block out 99% of sunlight. Also I am installing into brick pavers, instead of using Loop Locs 15 inch pipe (expensive) can I make my own from using 3/4 inch galvanized pipe cut down to 15 inches?
